RT-AC66U in media bridge with Verizon WIFI router issue.
HeroesInExile
hi all,
Long time lurker here and many special thanks to RMerlin for the work he has done.
In regards to my experience, I have an advanced knowledge of networking and network security including wireless.
I have a very specific issue that is escaping me, and it's a real stumper.
I am at work at the moment, but I will try to describe the problem, then submit a second post with hardware and configuration data, when i get home.
I have a Verizon WIFI router/Gateway for FIOS, i can access and configure settings but the Passthrough option that Verizon techs can perform is a nogo for my situation.
This gateway is then connected via 2.4 ghz wifi bridge to the ASUS RT-AC66U in media bridge mode so serve my network devices on another level of the house, providing ethernet connections over the bridge to those devices.
I am using RT-AC66U RMerlin firmware from DEC 2014 or JAN 2015, I will be able to provide excat version later. This issue has been occuring over several version including the firmware based on the 2013 wifi drivers in the ASUS base firmware(new versions of RMerlin firware run the updated 2014 wifi drivers).
All connections over the bridge and on the eth segment have static ips in the 192.168.1.* subnet.
DNS in both devices are set to 8.8.8.8 and 8.8.4.4 (Google DNS)
Ok, background and config done. Here's the issue. I have great connections, fast speed. About 1-2 times a week or more i have to "refresh the connection to the bridge via WIFI in the ASUS login. During a session of netflix, the endpoints on the eth connections loose "internet access" according to win7(the simple test of can it reach the MS server for DNS and download a small file). This being said i can login to all devices back and forth on the bridge no problem, even the Verizon gateway. The funny thing is if the wifi bridge went down, this would not happen, this is not a case for disconnection and disassociation of the network. Its almost as if the internet packets cease to transfer over the bridge to the ASUS router and eth endpoints.
I will reiterate, I still have a active connection to the 192. network, just not the internet, no dns resolution and no packets transfer out of the network to the internet , but still associated and authenticated to the WIFI bridge provided by the Verizon router. The only way to remediate this issue is to "Apply settings" or "reboot to apply settings" in the ASUS router.
During a netflix "show marathon" about 1 season long(13 episodes,30 minutes a piece) last night, I had to reboot the ASUS RT-AC66U about 6 times.
I hope this is enough to get the wheels turning out there. I have never encountered such a thing. Usually, and correct me if i'm wrong,network WIFI issues, its either all or nothing, connected or not, but not semi and no packet travel.
Troubleshooting performed, all host firewalls down, but i have not tried an actually packet capture with Wireshark or the like yet.
any ideas? More to come and thank you in advance.
hi all,
This is not a new issue. Media Bridge mode on the AC66U and the N66U have been reported to be "broken" by many others. I personally use one of my RT66U's in Media Bridge and do not experience the issues others have reported. With that in mind, you might want to try changing the channel you're using, or at the very least doing an area survey with something like InSSIDer or some other network scanning app to find the least congested channel in your particular environment.
If that doesn't seem to work, you might try using Repeater mode instead. I have another RT66U that is set up as a repeater, and no one has reported any of the issues that I've seen reported for Media Bridge mode. You will get close to the same throughput and speed from the LAN ports on your AC66U if set up in Repeater mode (admittedly the wifi from the Repeater will be much more greatly reduced...some say it's "half" but my experience has not been that severely impacted....I've experienced about 1/3 less throughput from the wireless radios on the Repeater. But the LAN ports work just great and you'll not see any of the stability issues that others have reported with the AC66U in Media Bridge mode.
Give that a try and let us know how it works for you.
I would use the built in MOCA features of your FIOS provided router if you have a coaxial outlet/drop nearby where your media center is.
Purchase an Actiontec MOCA coaxial/Ethernet adapter and a two way coaxial splitter (2 Ghz rated ).
Connect the adapter to the coaxial near your media center and then connect an Ethernet cable from the adapter to your AC66U and then put the AC66U in the AP mode. In the AP mode all five wired ports can be configured as LAN ports. You will also have a strong WiFi signal upstairs for portable devices.
You will then have what should be a rock steady wired connection. WiFi for video streaming is source of never ending frustration. Go MOCA.
