RT-AC66U IPv6 tunnel
marco92
Hi guys i have some problems on setting up my HE IPv6 tunnel on my RT-AC66U.
The router is running 378.54_1 firmware
Here is the settings of IPv6 config page:
Connection type: Tunnel 6rd
DHCP Option: Disable
IPv6 Prefix: (my routered /48 prefix)
IPv6 Prefix Length: 48
IPv4 Border Router: 216.66.80.30
IPv4 Router Mask Length: 24
Tunnel MTU: 1280 (same of HE tunnel advanced control page)
Tunnel TTL: 255
IPv6 DNS Server 1: 2001:470:20::2
IPv6 DNS Server 2: 2001:4860:4860::8888
IPv6 DNS Server 3: 2001:4860:4860::8844
Enable Router Advertisement: Enable
DHCPv6 Server: Enable
What's wrong?
I can't reach any IPv6 server from my local devices. Windows says that my IPv6 is "no access to internet".
If i try to ping some IPv6 server by SSH-ing into the router this is the result:
Marco@RT-AC66U:/# ping -6 www.google.com -w 10
PING www.google.com (2a00:1450:4001:807::1010): 56 data bytes
64 bytes from 2a00:1450:4001:807::1010: seq=0 ttl=58 time=31.078 ms
64 bytes from 2a00:1450:4001:807::1010: seq=1 ttl=58 time=25.891 ms
64 bytes from 2a00:1450:4001:807::1010: seq=2 ttl=58 time=25.955 ms
64 bytes from 2a00:1450:4001:807::1010: seq=3 ttl=58 time=30.067 ms
64 bytes from 2a00:1450:4001:807::1010: seq=4 ttl=58 time=25.825 ms
64 bytes from 2a00:1450:4001:807::1010: seq=5 ttl=58 time=28.545 ms
64 bytes from 2a00:1450:4001:807::1010: seq=6 ttl=58 time=28.702 ms
64 bytes from 2a00:1450:4001:807::1010: seq=7 ttl=58 time=25.922 ms
64 bytes from 2a00:1450:4001:807::1010: seq=8 ttl=58 time=26.128 ms
64 bytes from 2a00:1450:4001:807::1010: seq=9 ttl=58 time=26.130 ms
--- www.google.com ping statistics ---
10 packets transmitted, 10 packets received, 0% packet loss
round-trip min/avg/max = 25.825/27.424/31.078 ms
A traceroute to an IPv6 server:
Marco@RT-AC66U:/# traceroute -6 www.google.com -w 1 -m 12
traceroute to www.google.com (2a00:1450:4001:807::1010), 12 hops max, 16 byte packets
1 xxxxxx-1.tunnel.tserv6.fra1.ipv6.he.net (2001:470:xxxxx:xxxxx::1) 128.369 ms 47.788 ms 57.248 ms
2 v399.core1.fra1.he.net (2001:470:0:69::1) 62.548 ms 58.407 ms 39.596 ms
3 de-cix10.net.google.com (2001:7f8::3b41:0:1) 27.635 ms 80.991 ms 99.721 ms
4 2001:4860::1:0:4ca2 (2001:4860::1:0:4ca2) 62.451 ms 67.449 ms 39.163 ms
5 2001:4860:0:1::6ed (2001:4860:0:1::6ed) 24.732 ms 34.079 ms 57.221 ms
6 2a00:1450:4001:807::a (2a00:1450:4001:807::a) 49.807 ms 68.954 ms 59.306 ms
Tunnel seems to work... But I can't reach any IPv6 server from the local devices connected to the router (LAN devices)
P.S. Sorry for my bad english. XD
You mention HE, yet you have the tunnel set to 6rd. If you are really using a HE tunnel, set the mode to "6in4" instead.
Hi Erik...
I changed IPv6 tunnel configuration but LAN devices can't reach IPv6 servers.
Here is the configuration:
Connection type: Tunnel 6in4
Server IPv4 Address: 216.66.80.30
Client IPv6 Address: 2001:470:xxxx:xxxx::2 (copied from HE tunnelbroker's "Client IPv6 Address" field)
IPv6 Prefix Length: 64
Server IPv6 Address: 2001:470:xxxx:xxxx::1 (copied from HE tunnelbroker's "Server IPv6 Address" field)
Tunnel MTU: 1280 (same as HE tunnelbroker's MTU field on advanced config page)
Tunnel TTL: 255
LAN Prefix Length: 48
LAN IPv6 Prefix: 2001:470:xxxx:: (copied from HE tunnelbroker's "Routed /48" field)
IPv6 DNS Server 1: 2001:470:20::2 (copied from HE tunnelbroker's "Anycasted IPv6 Caching Nameserver" field)
IPv6 DNS Server 2: 2001:4860:4860::8888 (google IPv6 DNS)
IPv6 DNS Server 3: 2001:4860:4860::8844 (google IPv6 DNS)
Enable DHCPv6 Server: Enable
With this config IPv6 still work only on router (if i try to ping/traceroute an IPv6 server from SSH, the ping/traceroute works fine).
If i try to ping/traceroute the same server on any local device the ping/traceroute fails.
Regards,
Marco.
Re-check your tunnel configuration. HE tunnel is working fine for me.
The default routed tunnel from HE is a /64. Try with that prefix first, I've never tried with the /48 so I don't know the details of that particular setup (and I wonder who would need more than 2^64 IPs at home anyway).
If you are using the /48 routing, you have to make a special request to have it activated (I think there's a link off of the '?' button on the HE page).
Also, I just leave the mtu set as '0' for the default.
Also work's fine for me, with /64 prefix and '0' mtu settings.
still not working...
NEW CONFIG:
Tunnel MTU: 0
Tunnel TTL: 255
LAN Prefix Length: 64
LAN IPv6 Prefix: 2001:470:xxxx:xxx:: (copied from HE tunnelbroker's "Routed /64" field)
I deleted routed /48 from HE tunnelbroker's control page and re-setted tunnel MTU to 1480 on HE advanced control page.
I have problem with IPv6 tunnel since 376.44 release....
With releases before of 376.44 my IPv6 tunnel worked good.... (the settings was the same of tunnel 6rd that i posted on firs post.)
Make sure you have Ping enabled on the WAN interface, and that you are somehow updating the endpoint with your current IP (either through a script, or through the Tunnelbroker DDNS).
Ping is enabled on my firewall page... The tunnel endpoint is correcty updated by dnsomatic.
mark92.no-ip.org if you want to try pinging the router.
:eek:
I double cecked the tunnel broker's endpoint IP... It is the same that i have on my router's WAN port.
Ez-ipupdate send my IP to dns-o-matic, and dns-o-matic update my no-ip.org, tunnelbroker, and OpenDNS accounts.
No error from dns-o-matic service... In fact my ip is properly updated in each service
P.S. I did nvram reset after 378.50 firmware flash and manually re-conf the router.
Why are my Messages awaiting moderator approval every time?
I Finally found the problem!!!
All IPv6 tunnel config was correct... but if i only enable Parental Control the IPv6 tunnel stops working... Is it a normal thing?
