[RT-AC66U] Looking for information
rmondegar
Hello gentlemen,
I'm about to buy a brand new RT-AC66U, however, since I had bad experiences in the past, I'm doing some research first.
I don't mind paying a little more than the usual as long as the quality is the same as advertised, but since I'm also importing this, I would like to ask you guys:
- Does the router have any known issue, either with OFW or this Firmware ? I'm most interested in lower throughput, less coverage or loss of connection.
- Is it possible to use a script either in the OFW or this Firmware to setup the following QoS settings (as I had with DD-WRT):
/usr/sbin/tc qdisc add dev br0 root handle 1: htb
/usr/sbin/tc class add dev br0 parent 1: classid 1:1 htb rate 61440kbit
/usr/sbin/tc class add dev br0 parent 1:1 classid 1:10 htb rate 16384kbit ceil 24576kbit prio 1
/usr/sbin/tc class add dev br0 parent 1:1 classid 1:11 htb rate 16384kbit ceil 24576kbit prio 1
/usr/sbin/tc class add dev br0 parent 1:1 classid 1:12 htb rate 4096kbit ceil 5120kbit prio 4
/usr/sbin/tc qdisc add dev br0 parent 1:10 handle 10: sfq perturb 10
/usr/sbin/tc qdisc add dev br0 parent 1:11 handle 11: sfq perturb 10
/usr/sbin/tc qdisc add dev br0 parent 1:12 handle 12: sfq perturb 10
/usr/sbin/tc filter add dev br0 parent 1:0 prio 1 protocol ip handle 10 fw flowid 1:10
/usr/sbin/tc filter add dev br0 parent 1:0 prio 7 protocol ip handle 10 fw flowid 1:100
/usr/sbin/tc filter add dev br0 parent 1:0 prio 1 protocol ip handle 11 fw flowid 1:11
/usr/sbin/tc filter add dev br0 parent 1:0 prio 7 protocol ip handle 11 fw flowid 1:110
/usr/sbin/tc filter add dev br0 parent 1:0 prio 4 protocol ip handle 12 fw flowid 1:12
/sbin/insmod imq
/sbin/insmod ipt_IMQ
/usr/sbin/ip link set imq0 up
/usr/sbin/tc qdisc add dev imq0 root handle 1: htb
/usr/sbin/tc class add dev imq0 parent 1: classid 1:1 htb rate 3072kbit
/usr/sbin/tc class add dev imq0 parent 1:1 classid 1:10 htb rate 320kbit ceil 320kbit prio 1
/usr/sbin/tc class add dev imq0 parent 1:1 classid 1:11 htb rate 320kbit ceil 320kbit prio 1
/usr/sbin/tc class add dev imq0 parent 1:1 classid 1:12 htb rate 128kbit ceil 128kbit prio 4
/usr/sbin/tc qdisc add dev imq0 parent 1:10 handle 10: sfq perturb 10
/usr/sbin/tc qdisc add dev imq0 parent 1:11 handle 11: sfq perturb 10
/usr/sbin/tc qdisc add dev imq0 parent 1:12 handle 12: sfq perturb 10
/usr/sbin/tc filter add dev imq0 parent 1:0 prio 1 protocol ip handle 10 fw flowid 1:10
/usr/sbin/tc filter add dev imq0 parent 1:0 prio 7 protocol ip handle 10 fw flowid 1:100
/usr/sbin/tc filter add dev imq0 parent 1:0 prio 1 protocol ip handle 11 fw flowid 1:11
/usr/sbin/tc filter add dev imq0 parent 1:0 prio 7 protocol ip handle 11 fw flowid 1:110
/usr/sbin/tc filter add dev imq0 parent 1:0 prio 4 protocol ip handle 12 fw flowid 1:12
/usr/sbin/iptables -t mangle -A POSTROUTING -s ! 192.168.1.0/24 -d 192.168.1.2 -p tcp --dport 44444 -j MARK --set-mark 100
/usr/sbin/iptables -t mangle -A POSTROUTING -s ! 192.168.1.0/24 -d 192.168.1.2 -p ucp --dport 44444 -j MARK --set-mark 100
/usr/sbin/iptables -t mangle -A POSTROUTING -s ! 192.168.1.0/24 -d 192.168.1.3 -p tcp --dport 44445 -j MARK --set-mark 110
/usr/sbin/iptables -t mangle -A POSTROUTING -s ! 192.168.1.0/24 -d 192.168.1.3 -p ucp --dport 44445 -j MARK --set-mark 110
/usr/sbin/iptables -t mangle -A POSTROUTING -s ! 192.168.1.0/24 -d 192.168.1.2 -j MARK --set-mark 10
/usr/sbin/iptables -t mangle -A POSTROUTING -s ! 192.168.1.0/24 -d 192.168.1.3 -j MARK --set-mark 11
/usr/sbin/iptables -t mangle -A POSTROUTING -s ! 192.168.1.0/24 -d 192.168.1.128/25 -j MARK --set-mark 12
/usr/sbin/iptables -t mangle -A PREROUTING -j IMQ --todev 0
/usr/sbin/iptables -t mangle -A PREROUTING -d ! 192.168.1.0/24 -s 192.168.1.2 -p tcp --dport 44444 -j MARK --set-mark 100
/usr/sbin/iptables -t mangle -A PREROUTING -d ! 192.168.1.0/24 -s 192.168.1.2 -p udp --dport 44444 -j MARK --set-mark 100
/usr/sbin/iptables -t mangle -A PREROUTING -d ! 192.168.1.0/24 -s 192.168.1.3 -p tcp --dport 44445 -j MARK --set-mark 110
/usr/sbin/iptables -t mangle -A PREROUTING -d ! 192.168.1.0/24 -s 192.168.1.3 -p udp --dport 44445 -j MARK --set-mark 110
/usr/sbin/iptables -t mangle -A PREROUTING -d ! 192.168.1.0/24 -s 192.168.1.2 -j MARK --set-mark 10
/usr/sbin/iptables -t mangle -A PREROUTING -d ! 192.168.1.0/24 -s 192.168.1.3 -j MARK --set-mark 11
/usr/sbin/iptables -t mangle -A PREROUTING -d ! 192.168.1.0/24 -s 192.168.1.128/25 -j MARK --set-mark 12
I know it is possible to do this using DD-WRT, however, I had bad experience in the past with several routers performance in comparison to the OFW.
Thanks in advance,
Ralph Mondegar
With Asuswrt-Merlin you should be able to set up the QOS rules using the custom script support (or even custom config support, not sure how QOS is set up since I'm satisfied with the built in QOS support).
Thanks for the replies. Would be nice if someone could confirm that with asuswrt-merlin I could set up a custom script like that and that are no major issues, like rebooting router, lower througput in comparison to the stock or signal loss.
AC isn't even a finalized spec yet. Take a look at the threads here and draw your own conclusion on how many people are experiencing "major issues." Granted this is an experimental demographic, but even multi stream N routers are just barely settling in a nice, consistent groove right now. Signal levels are varying wildly right now (across multiple models) due to some lower level driver changes.
