RT-AC66U, Merlin's FW beta3, VyprVPN
VNMan
Just bought myself a new RT-AC66u, flashed the router with Merlin's beta3 firmware.
I have success in connecting to VyprVPN using OpenVPN, the PC and MAc that I tested on confirmed that VPN is working, but I have problem with my xbox 360, it failed always with "mtu error".
This is what I did -
Followed the instructions from various websites -
Set Start with WAN to Enabled.
Set Interface Type to Tun.
Set Protocol to UDP.
Set the Server Address/Port to uk1.vpn.giganews.com and port to 1194.
Set the Firewall to Automatic.
Set Authorization Mode to TLS.
Set Extra HMAC authorization to Disabled.
Set Create NAT on tunnel to Enabled.
Set Poll Interval to 0.
Set Redirect Internet Traffic to Disabled.
Set Accept DNS configuration to Enabled.
Set Encryption cipher to (Use Default).
Set Compression to (Adaptive).
And in "Custom Configuration" I have
persist-key
persist-tun
tun-mtu 1500
tun-mtu-extra 32
mssfix 1450
comp-lzo adaptive
verb 1
reneg-sec 0
Hope someone can help
Thanks in advance.
Seems that there is no way to get xbox to go via vpn, bump
Got in contact with giganews support and posted my config and the reply was that "your router and xbox is unsupported...".
According to giganews support I have to use ISC if I want to connect xbox through vpn and this is NOT what I want to do.
A Tailscale and Asus Merlin Router VPN 16
