RT-AC66U needs rebooting daily
jjulez
Running merlin 380.59..it were working fine until i install windows 10 and it
started this...I installed windows 10 saturday it started doing this sunday no
internet access wifi & wired
Device drivers, all W10 compatible?
Yes, windows 10 were on it before but if was the upgrade version
this install were a clean one.
All Windows updates applied? Last few patch Tuesdays addressed wifi issues/stability. I would also remove all connections and reconnect them after a reboot. Been running Windows 10 since its beta with an AC66 and no real issues with wifi to speak of for a while now. I will say I recently had slow downs with speed on LAN and 5ghz wireless and a nvram clear on the AC66 was the solution. Have a 1gb fiber connection and can typically get 600+ LAN speeds on speedtests and 250-300 mbps on 5ghz wifi (AC). It has dropped to 175mbps on the 5ghz and about 300mbps or so on LAN. After trying a lot of things I finally cleared nvram and things got back to normal when it rebooted afterwards. Anyway point being perhaps that may resolve your issue.
