Hello from Russia
I have problem with forwarding for http / 80.
In my network working web server on 192.168.1.23 with nginx (80 port). GUI on router using same port. I tried change UI from 80 to 8443 for release port, but rule for port forwarding not work.
If i set 8080 port for nginx and 8080 in rule on router. site - availible.
If i set 80 port for nginx and 80 in rule on router, site - not availible.
I took for test Netgear 600 and did the same. Move UI to another port and set port 80 and rule for 80. Site availible with out problems.
Questions: Can you make options in menu or write command (from console ssh), for forced change the port of UI which allow use PortForward rule with 80->80?
Change UI autorization form HTTP to HTTPS not solves the problem.
Firmware:378.53
Firmware:378.53
