pepemosca
Hello,
I would like to know if it's possible to set up Apple's Time Machine using the USB port on the Asus RT-AC66U.
I can follow these tutorials:
http://www.insanelymac.com/forum/to...leopard-time-machine-backup-to-network-share/
http://lifehacker.com/5691649/an-ea...ne-to-back-up-to-a-networked-windows-computer
But when I run this code:
I get this error:
Thank you.
Regards!
sudo tmutil setdestination /Volumes/TimeMachine/
/Volumes/TimeMachine: Incompatible file system type: smbfs (error 45)
Thank you.
Regards!
