A 9 month ago i was managed to hook-up 4 TB HDD to RT-AC66U_b1 and it worked pretty well on NTFS for a year! 9 month after I dismount HDD for HW check because web-ui NTFS check dont work for 4 TB anyway. I preformed chekdisk (100% good) and defrag. After that i huked-up drive to rauter and get 100% CPU utilization and no volume mounting. RAM is on 50%.
repeating indefinitely.
Or 2 or 4. Depends what i tried in struggle.
NTFS volume is "/dev/sda4: UUID="B60F4AFC9C8D5AD5"" obviously.
I checked it:
PS:
I turn-off all I can imagine for USB-HDD (as SMB/FTP/DM/Logs etc)
ver.384.13
Aug 27 19:57:36 kernel: device blocksize: 512
Aug 27 19:57:36 kernel: __find_get_block_slow() failed. block=6158477664, b_blocknr=1863510368
PID USER VSZ STAT COMMAND
1903 %myusrname% 5272 S /sbin/asus_sd sda3 add
1 %myusrname% 5280 D /sbin/preinit
2 %myusrname% 0 SW [kthreadd]
3 %myusrname% 0 SW [ksoftirqd/0]
4 %myusrname% 0 SW [kworker/0:0]
5 %myusrname% 0 SW [kworker/u:0]
6 %myusrname% 0 SW [migration/0]
7 %myusrname% 0 SW [migration/1]
8 %myusrname% 0 SW [kworker/1:0]
9 %myusrname% 0 SW [ksoftirqd/1]
10 %myusrname% 0 SW< [khelper]
11 %myusrname% 0 SW [sync_supers]
12 %myusrname% 0 SW [bdi-default]
13 %myusrname% 0 SW< [kblockd]
14 %myusrname% 0 SW [kswapd0]
15 %myusrname% 0 SW [fsnotify_mark]
16 %myusrname% 0 SW< [crypto]
24 %myusrname% 0 SW [mtdblock0]
25 %myusrname% 0 SW [mtdblock1]
26 %myusrname% 0 SW [mtdblock2]
27 %myusrname% 0 SW [mtdblock3]
28 %myusrname% 0 SW [kworker/u:1]
35 %myusrname% 0 SW [kworker/0:1]
36 %myusrname% 0 SW [kworker/1:1]
37 %myusrname% 0 SW [mtdblock4]
38 %myusrname% 0 SW [mtdblock5]
40 %myusrname% 664 S hotplug2 --persistent --no-coldplug
88 %myusrname% 5268 S console
94 %myusrname% 0 SWN [jffs2_gcd_mtd4]
101 %myusrname% 1412 S /sbin/syslogd -m 0 -S -O /tmp/syslog.log -s 256 -l 6
103 %myusrname% 1416 S /sbin/klogd -c 5
171 %myusrname% 5276 S /sbin/wanduck
178 %myusrname% 5048 S nt_monitor
179 %myusrname% 2068 S protect_srv
180 %myusrname% 5292 S /sbin/netool
187 %myusrname% 5292 S /sbin/netool
188 %myusrname% 5292 S /sbin/netool
191 %myusrname% 2068 S protect_srv
192 %myusrname% 2068 S protect_srv
193 %myusrname% 1152 S dropbear -p 192.168.1.1:22 -j -k
195 %myusrname% 5048 S nt_monitor
196 %myusrname% 5048 S nt_monitor
198 %myusrname% 5196 S nt_center
199 %myusrname% 1268 S /bin/eapd
201 %myusrname% 5272 S wpsaide
202 %myusrname% 2140 S /usr/sbin/wlc_nt
207 %myusrname% 5196 S nt_center
208 %myusrname% 5196 S nt_center
209 %myusrname% 1836 S nas
216 %myusrname% 2260 S /usr/sbin/wlceventd
218 %myusrname% 5048 S nt_monitor
220 %myusrname% 1672 S nt_actMail
221 %myusrname% 1672 S nt_actMail
222 %myusrname% 1672 S nt_actMail
224 %myusrname% 1444 S /usr/sbin/acsd
227 nobody 3200 S dnsmasq --log-async
228 %myusrname% 3188 S dnsmasq --log-async
235 %myusrname% 1440 S crond -l 9
253 %myusrname% 5800 S httpds -s -i br0 -p 8443
254 %myusrname% 5800 S httpd -i br0
255 %myusrname% 1240 S /usr/sbin/infosvr br0
258 %myusrname% 1240 S sysstate
259 %myusrname% 5272 S watchdog
264 %myusrname% 1240 S cstats
265 %myusrname% 2824 S rstats
279 %myusrname% 1280 S lld2d br0
280 %myusrname% 5860 S networkmap --bootwait
283 %myusrname% 5024 S mastiff
284 %myusrname% 5272 S bwdpi_check
286 %myusrname% 5272 S pctime
291 %myusrname% 5272 S erp_monitor
294 %myusrname% 660 S /usr/sbin/sd-idle-2.6 -i 900
300 %myusrname% 1484 S lldpd -L /usr/sbin/lldpcli -I vlan1,eth1,eth2,wds0.*,wds1.*,wds2.* -s RT-AC68U
304 nobody 1456 S lldpd -L /usr/sbin/lldpcli -I vlan1,eth1,eth2,wds0.*,wds1.*,wds2.* -s RT-AC68U
305 %myusrname% 3844 S cfg_server
321 %myusrname% 5280 S amas_lib
344 %myusrname% 0 SW [khubd]
378 %myusrname% 5280 S amas_lib
382 %myusrname% 5024 S mastiff
383 %myusrname% 5024 S mastiff
384 %myusrname% 5024 S mastiff
423 %myusrname% 3844 S cfg_server
424 %myusrname% 3844 S cfg_server
495 %myusrname% 5272 S usbled
496 %myusrname% 2444 S u2ec
497 %myusrname% 1312 S lpd br0
499 %myusrname% 2444 S u2ec
500 %myusrname% 2444 S u2ec
550 %myusrname% 1432 S /usr/sbin/ntp -t -S /sbin/ntpd_synced -p pool.ntp.org -p time.nist.gov
560 %myusrname% 5272 S disk_monitor
588 %myusrname% 8672 S aaews --sdk_log_dir=/tmp
596 %myusrname% 8672 S aaews --sdk_log_dir=/tmp
597 %myusrname% 8672 S aaews --sdk_log_dir=/tmp
598 %myusrname% 8672 S aaews --sdk_log_dir=/tmp
599 %myusrname% 8672 S aaews --sdk_log_dir=/tmp
600 %myusrname% 8672 S aaews --sdk_log_dir=/tmp
601 %myusrname% 8672 S aaews --sdk_log_dir=/tmp
620 %myusrname% 1788 S dcd -i 3600 -p 43200 -b -d /tmp/bwdpi/
621 %myusrname% 2944 S wred -B
622 %myusrname% 1788 S dcd -i 3600 -p 43200 -b -d /tmp/bwdpi/
623 %myusrname% 1788 S dcd -i 3600 -p 43200 -b -d /tmp/bwdpi/
624 %myusrname% 2944 S wred -B
625 %myusrname% 2944 S wred -B
626 %myusrname% 1788 S dcd -i 3600 -p 43200 -b -d /tmp/bwdpi/
627 %myusrname% 1788 S dcd -i 3600 -p 43200 -b -d /tmp/bwdpi/
628 %myusrname% 1788 S dcd -i 3600 -p 43200 -b -d /tmp/bwdpi/
658 %myusrname% 2944 S wred -B
659 %myusrname% 2944 S wred -B
660 %myusrname% 2944 S wred -B
661 %myusrname% 2944 S wred -B
662 %myusrname% 2944 S wred -B
663 %myusrname% 2944 S wred -B
664 %myusrname% 2944 S wred -B
665 %myusrname% 2944 S wred -B
682 %myusrname% 5272 S bwdpi_wred_alive
703 %myusrname% 664 S tcd
1087 %myusrname% 1428 S /sbin/udhcpc -i eth0 -p /var/run/udhcpc0.pid -s /tmp/udhcpc -O33 -O249
1283 %myusrname% 8672 S aaews --sdk_log_dir=/tmp
1837 %myusrname% 1184 S dropbear -p 192.168.1.1:22 -j -k
1838 %myusrname% 1424 S -sh
2227 %myusrname% 1176 S dropbear -p 192.168.1.1:22 -j -k
2237 %myusrname% 1424 S -sh
2296 %myusrname% 0 SW [scsi_eh_0]
2298 %myusrname% 0 SW [usb-storage]
2313 %myusrname% 688 S hotplug2 --persistent --no-coldplug
2317 %myusrname% 688 S hotplug2 --persistent --no-coldplug
2318 %myusrname% 5272 S /sbin/asus_sd sda4 add
2320 %myusrname% 5272 S /sbin/asus_sd sda add
2328 %myusrname% 5336 S hotplug block
2331 %myusrname% 5272 S hotplug block
2338 %myusrname% 0 SW [jbd2/sda2-8]
2339 %myusrname% 0 SW< [ext4-dio-unwrit]
2361 %myusrname% 0 SW [flush-8:0]
2369 %myusrname% 0 SW [jbd2/sda3-8]
2370 %myusrname% 0 SW< [ext4-dio-unwrit]
2395 nobody 1536 S avahi-daemon: running [RT-AC66U_B1-F840.local]
2397 %myusrname% 1412 R mount -t tntfs -o umask=0000,nodev,nls=utf8 /dev/sda4 /tmp/mnt/filev
2456 %myusrname% 1416 R ps -T
Filesystem Type Size Used Available Use% Mounted on
/dev/root squashfs 32.5M 32.5M 0 100% /
devtmpfs devtmpfs 124.7M 0 124.7M 0% /dev
tmpfs tmpfs 124.8M 1.7M 123.2M 1% /tmp
/dev/mtdblock4 jffs2 62.8M 10.7M 52.0M 17% /jffs
/dev/sda2 ext4 4.7G 16.0E 4.5G 100% /tmp/mnt/progsv
/dev/sda3 ext4 6.6G 8.0M 6.2G 0% /tmp/mnt/tempv
and
/dev/sda3: LABEL="tempv" UUID="fbbfba1f-f75c-d501-e0a1-ba1ff75cd501"
/dev/sda2: LABEL="progsv" UUID="f87e3618-f75c-d501-b058-3618f75cd501"
/dev/sda1: LABEL="swapv" UUID="a8da7196-6a4c-ee3f-c0cb-1b01d8cc896c"
and
and
/dev/sda1: UUID="B60F4AFC9C8D5AD5"
and
I checked it:
- at usb2 port. without chsnges
- with another GPT-NTFS-formatted HDD (1TB) - works ideally
- with up to 3 additional linux volumes and NTFS-only at 4TB drive
- reset to "factory defaults" and load 100% working config and jffs
PS:
ver.384.13
