I have a 2tb USB 2.0 drive plugged into my AC68. The drive shows up in Finder as being on the local wireless network just fine. However, when I try to drag files to it wirelessly, Finder asks me to login ("Finder wants to make changes...") and then says I don't have permission.
Weirdly, if I create a new folder on the same drive I can drag and drop files no problem. No prompt for login. It's only preexisting folders on the drive that are a problem.
Looking at Get Info I don't have the ability to change permissions. It just says I have "custom access."
When the same drive is connected directly to my computer, I don't have any permissions issues with any folders on that drive. So I'm trying to figure out why I can't drop files into certain folders when it is plugged into the AC68.
Using Merlin 376.49_5, OSX Mavericks
