RT AC68-U 380.7266 possible WPS bug?
HockeyJohn83
Hey
I have the AC68U and did factory reset it after upgrading to 380.7266. I configured it and rebooted it and it was after this that I noticed that WPS was enabled. I am certain I didn't enable it myself.
Is this a known issue/Has anyone else found WPS enabled by itself?
Saw that the latest FW (380.7378) came out a few days ago. Anyone running this who has this issue as well?
Do a factory reset and WPS will be on. Not a bug but the way it works. Merlin firmware has WPS off by default.
Sent from my P01M using Tapatalk
Looks like I'm not the only one with this issue. Did you disable it, and if so, has it stayed that way?
I disable WPS as part of my configuration so it did randomly enable itself later on (not sure if related to the reboot, but that's when i noticed).
