So, I'm trying to nail down this annoying problem i've been having with my router. Lately, it's been dropping wifi to all devices attached. In troubleshooting, I checked my ethernet connected computer and ran some tests on it during the problem and this is what came up. I thought it might just be wifi, but when it happens, my ethernet pc also start slowing/losing connection. When it happens, it usually occurs for about 5min or so. Then it comes back up like nothing occurred.
I apologize if this is the wrong way to post this! Is this ok, or its better if I use a service like pastebin?
I am on the firmware (i believe its the latest): 3.0.0.4.386_43129-g60defb2
RT-AC68R syslog taken right after the router login page came back up online (done from wired ethernet system):
Ping tests I ran to router during the problem which shows a huge slow down during the problem (done on wired ethernet system):
https://pastebin.com/X1pUtpxg
Tracepath tests I ran to web during the problem which shows a huge slow down during the problem (done on wired ethernet system):
Any thoughts ideas as to why this might be happening?
It was suggested maybe it needs cleaning and the CPU is spiking? Is there a best way to clean it or take it apart?
I was thinking if there's a way to log the CPU activity , but I don't see that? I do have ssh access on the router, but don't see crontab?
Thank you
Oct 11 22:12:24 kernel: DROP IN=vlan2 OUT= MAC=e0:3f:49:29:74:f8:00:01:5c:77:46:46:08:00:45:00:00:28 SRC=137.184.112.247 DST=
LEN=40 TOS=0x00 PREC=0x00 TTL=241 ID=39317 PROTO=TCP SPT=32766 DPT=7400 SEQ=104951496 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
LEN=40 TOS=0x00 PREC=0x00 TTL=241 ID=54212 PROTO=TCP SPT=32766 DPT=60091 SEQ=3854684874 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Oct 11 22:12:48 syslog: wlceventd_proc_event(527): eth1: Auth 6C:88:14:BF:17:3C, status: Successful (0), rssi:0
Oct 11 22:12:59 syslog: wlceventd_proc_event(527): eth1: Auth 6C:88:14:BF:17:3C, status: Successful (0), rssi:0
Oct 11 22:13:11 syslog: wlceventd_proc_event(527): eth1: Auth 6C:88:14:BF:17:3C, status: Successful (0), rssi:0
Oct 11 22:13:26 syslog: wlceventd_proc_event(527): eth1: Auth 6C:88:14:BF:17:3C, status: Successful (0), rssi:0
Oct 11 22:13:38 syslog: wlceventd_proc_event(527): eth1: Auth 6C:88:14:BF:17:3C, status: Successful (0), rssi:0
Oct 11 22:13:52 syslog: wlceventd_proc_event(527): eth1: Auth 6C:88:14:BF:17:3C, status: Successful (0), rssi:-72
Oct 11 22:13:52 syslog: wlceventd_proc_event(556): eth1: Assoc 6C:88:14:BF:17:3C, status: Successful (0), rssi:-72
Oct 11 22:13:55 syslog: wlceventd_proc_event(527): eth1: Auth 1C:99:4C:55:D4:9D, status: Successful (0), rssi:0
Oct 11 22:13:55 syslog: wlceventd_proc_event(556): eth1: Assoc 1C:99:4C:55:D4:9D, status: Successful (0), rssi:0
Oct 11 22:13:56 syslog: wlceventd_proc_event(556): eth1: Assoc 1C:99:4C:55:D4:9D, status: Successful (0), rssi:0
Oct 11 22:13:57 syslog: wlceventd_proc_event(527): eth1: Auth 1C:99:4C:55:D4:9D, status: Successful (0), rssi:0
Oct 11 22:14:00 syslog: wlceventd_proc_event(527): eth1: Auth 1C:99:4C:55:D4:9D, status: Successful (0), rssi:0
Oct 11 22:14:03 syslog: wlceventd_proc_event(556): eth1: Assoc 1C:99:4C:55:D4:9D, status: Successful (0), rssi:0
Oct 11 22:14:03 syslog: wlceventd_proc_event(527): eth1: Auth 1C:99:4C:55:D4:9D, status: Successful (0), rssi:0
Oct 11 22:14:03 syslog: wlceventd_proc_event(491): eth1: Deauth_ind 6C:88:14:BF:17:3C, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Oct 11 22:14:07 syslog: wlceventd_proc_event(527): eth1: Auth 1C:99:4C:55:D4:9D, status: Successful (0), rssi:-42
Oct 11 22:14:07 syslog: wlceventd_proc_event(556): eth1: Assoc 1C:99:4C:55:D4:9D, status: Successful (0), rssi:-42
Oct 11 22:14:17 syslog: wlceventd_proc_event(491): eth1: Deauth_ind 1C:99:4C:55:D4:9D, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-39
Oct 11 22:18:03 syslog: wlceventd_proc_event(527): eth1: Auth 1C:99:4C:55:D4:9D, status: Successful (0), rssi:0
Oct 11 22:18:05 syslog: wlceventd_proc_event(556): eth1: Assoc 1C:99:4C:55:D4:9D, status: Successful (0), rssi:-49
Oct 11 22:18:13 kernel: DROP IN=vlan2 OUT= MAC=e0:3f:49:29:74:f8:00:01:5c:77:46:46:08:00:45:00:00:28 SRC=137.184.112.247 DST=
LEN=40 TOS=0x00 PREC=0x00 TTL=241 ID=12351 PROTO=TCP SPT=32766 DPT=15340 SEQ=3350388838 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
LEN=40 TOS=0x00 PREC=0x00 TTL=241 ID=11506 PROTO=TCP SPT=32766 DPT=16242 SEQ=1816066101 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
LEN=40 TOS=0x00 PREC=0x00 TTL=241 ID=27591 PROTO=TCP SPT=32766 DPT=28341 SEQ=456519367 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
$ tracepath yahoo.com
1?: [LOCALHOST] pmtu 1500
1: _gateway 0.369ms
1: _gateway 2.861ms
2: 142-254-130-177.inf.spectrum.com 1426.535ms
2: 142-254-130-177.inf.spectrum.com 7479.282ms
3: no reply
4: agg20.plantxmp02r.texas.rr.com 2967.852ms
4: agg20.plantxmp02r.texas.rr.com 4809.644ms
4: agg20.plantxmp02r.texas.rr.com 8040.456ms
5: agg27.dllbtxlb02r.texas.rr.com 1430.388ms
5: agg27.dllbtxlb02r.texas.rr.com 1865.355ms
6: agg21.hstqtxl301r.texas.rr.com 1413.913ms
6: agg21.hstqtxl301r.texas.rr.com 3242.502ms
7: 66.109.9.88 1429.974ms
7: 66.109.9.88 1879.719ms
8: no reply
8: 107.14.19.49 3228.773ms asymm 9
8: bu-ether12.dllstx976iw-bcr00.tbone.rr.com 7054.902ms asymm 9
8: bu-ether12.dllstx976iw-bcr00.tbone.rr.com 6497.444ms asymm 9
9: 209-18-43-77.dfw10.tbone.rr.com 6907.561ms
9: 209-18-43-77.dfw10.tbone.rr.com 11580.669ms
10: unknown.yahoo.com 2863.883ms asymm 9
10: xe-0-0-23.pat1.dax.yahoo.com 7555.663ms asymm 9
10: unknown.yahoo.com 7991.147ms asymm 9
11: ae-5.pat1.che.yahoo.com 2855.248ms
11: ae-5.pat1.che.yahoo.com 8903.732ms
11: ae-5.pat2.che.yahoo.com 9327.873ms
Thank you
