Ryogo
I've purchased pre-owned RT-AC68R it came with stock FW, I made short testing to make sure everything working fine. After that:
1) flashed Tomato (through FW web ui, not recovery mode);
2) booted into Tomato;
3) plugged usb2 hdd (usb powered) to the router usb2 port;
4) started configuring settings (smb share / dlna server);
While I was on step 4 wi-fi has stopped working and not it won't work anymore.
I tried erasing nvram in recovery mode and flashing back to stock through recovery but that didn't helped.
Also, when I press power every router led blinks (as it suposed to) except those 2 that show wi-fi status.
Any suggestions?
UPD: strange thing - usb ports don't work.
If I flash Tomato again - usb ports are working. Flashing stock/merlin without nvram reset - ports still working. Doing nvram reset on stock/merlin - usb ports are not working again.
Any suggestions?
