RT-AC68U as OpenVPN client
DotComm
I'm having some trouble here. I have a remote OpenVPN server I wish to have my network connect to. Other clients are able to connect to the server just fine and their traffic is working all correctly. I have brought over my config file to the router and it is able to connect fine. However, I am not able to ping the OpenVPN server using the VPN ip nor can anything on the VPN ping the router. I got a feeling I need some sort of iptables rule on the router side, but haven't been able to figure anything out. My most recent try, and what I though would open it up the most was adding rules:
-A INPUT -i tap11 -j ACCEPT
-A OUTPUT -o tap11 -j ACCEPT
My router is RT-AC68U running Merlin's custom firmware version 276.47
Anyone got any sort of advice?
It's possible the VPN administrator has disabled ICMP traffic. Is there an internal resource, like a web server, you could try connecting to? Do you yourself have a laptop or other unit that you've been using to VPN in with before the router? If so check the config of that client.
I've tried connecting to another machine on the VPN. I just copied over a working config from another machine that does work. Again, it connects, but I cannot send or receive any traffic over the connection. The VPN status page reads that traffic is being sent and received, which is why I still believe I have a firewall issue somewhere.
