RT-AC68U ASUS-Merlin 380.68_2 QoS with BT issue
Noodle04
Hi Forum,
I'm using ASUS-Merlin on a RT-AC68U router (T-mobile one I believe). It was working great.
Recently (probably 380.63, not sure) router keep crashing in few seconds to minutes when I use BT to download. This only happened when QoS is enabled. I tried different QoS settings, but none of them help.
BT was on another machine, not running on router. Once I disable QoS on router, everything work fine.
Anybody have any idea how can I debug this?
Noodle
Hi Forum,
Noodle
did you factory reset after the firmware update and manually re input you settings
can you post the system log when the issue happens
what port does your torrent client use
