RT-AC68U Bootloader (CFE) issue
mallesh
I am trying to access bootloader of asus rt-ac68u router using serial port and putty. Unable to get cfe prompt in the terminal(even after pressing ctrl-c or Esc). That bootlog never ending and the log is in waiting state with the message saying "starting ntp.."(see the attached log).
Try CTRL + Z, bootloader seems to be working fine, NTP is waiting to reach the Internet, probably you dont have it connected.
Tried CTRL+Z also, but it is not working. No problem with ntp start/internet connection(see the updated attached log). looking forward for other options.
What CFE version?
Wrong info, check the CFE version on the FW.
