rageagainstjg
Hello all, first post here so hopefully not breaking any rules. I have a RT-AC68U that is running 3.1.1.4.378_4585 firmware, this originally was one of the t-mobile routers that I flashed as soon as I got it. My problem is that I have setup ddns using the hostname.asuscomm.com and I can access this on a computer outside of my local network but only if i go into the router and first turn off the router firewall from a computer located on the network. If the router firewall is turned on i can not access my router remotely, if the router firewall is turned off I can access it remotely. Do you know of a setting that I should change on my routers firewall in order to access it remotely? My eventual goal is to do some port forwarding but first I want to be able to just access my router remotely without having to turn off it's firewall. With the firewall turned on this is what is says,
Settings have been updated. Web page will now refresh.
Changes have been made to the IP address or port number. You will now be disconnected from TM-AC1900.
To access the settings of TM-AC1900, reconnect to the wireless network and use the updated IP address and port number. It keeps saying TM-AC1900 because of it originally being a t-mobile router. If I turn off the firewall everything works just fine.
