ualdrivr
I've tried everything. I believe it's a Firmware issue. The WiFi printing sometimes works flawlessly and some times it doesn't.
I have re-installed the printer driver for my Epson all in one WorkForce 845 and it seems to be working all right. But when it comes to AirPrint form my iPhone or iPad then all bets are off.
The printer shows on my Network fine, I even gave it a Static IP. When I check Confirm Network setting on the printer, everything looks great. I pick a PDF document to print from my iPad or iPhone and all hell breaks lose. It prints one to three lines and then it stops, the router reboots and throws everything off the Network and then it restarts it self.![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
This is very annoying and needs to be addressed ASUS!!! I have contacted Support with very little help. All I heard is that they are working on new Firmware. I put a 3 star review on the router on Newegg, because of this problem. More testing is required on the router, so it plays nice with everything and all printers.
Firmware version: 3.0.0.4.374_4561
Having said that, I do love the power and range of this router. I've had it for over a month now and it has stabilized significantly from the first couple of days. My wife's laptop which is at the furthest point from the router with four walls in between and equipped with the AC-51 USB Asus adapter gets 117 to 88 Mbps consistently, if I get near the router 433.3 Mbps is not out of reach.
Any other guys have experienced problems with Airprint?
