Hi.
There is made one specified firmware for the RT-AC68U fo being able to setup a guest Wi-Fi that will give you access to the guest network, if the user check-in to a Facebook page. (3.0.0.4.380.2717 firmware).
The only problem with this firmware is that it is missing one very important setting. It is allowing full access to the network except thru port 80, that is when you are redirected to the Facebook check-in site.
We want to be able to block everything until the check-in has been done. I know this can work, because I borrowed a Cisco Meraki MR18 from work for testing and there you have the option:
The question from all of us is if there is possible that the firmware 3.0.0.4.380.2717 on the RT-AC68U can be modified so that it can have the block everything setting?
- Allow non-HTTP traffic prior to sign-on: All traffic types except for TCP port 80 are allowed before the splash page is acknowledged.
- Block all access until sign-on is complete All traffic types are blocked until the splash page is acknowledged.
