gatorback
I was inspired by this post 337 to install a fan:
http://www.snbforums.com/threads/overclocking-rt-ac56u.12578/page-17
I'd like to do something similar with perhaps 2 fans on an RT-AC68U. This does not use a USB port (very desirable feature), so hopefully someone has done this already. It's not clear what the voltage is available inside, but the power supply is 19V. There must be a 5V node for the USB. Can anyone confirm if there is a 12V pickoff?
Noise is a consideration and the speed control would definitely be a plus. If you have had a good experience with a fan suitable for this scenario, please post a link to purchase this item. Any electrical fan experience with the RT-AC68U is appreciated. Please state the router model you modded when commenting
