actualy i'm going test again .... seems sometimes it work sometimes it doesntThanks for the data point.
However.
That decade-old design/hardware is great for Media Bridge mode. Well past its best-before-due date in router mode (at least for the faster ISP speeds available today).
Even overclocked, an entry-level AX class router such as an RT-AX68U will overshadow it (and yes, even with 'only' AC class clients).
What frequency are you overclocked to?just here to inform i found overclocking the rt-ac68u (older versions) not working anymore with firmware 386.11 (i use merlin), 386.10 is the last known version that overclocking still works for me
nvram get clkfreq
1000/800
cat /proc/cpuinfo | grep Bogo
BogoMIPS : 1998.84
BogoMIPS : 1992.29
I agree 100% if you don't mitigate the heat BUT up until recently, when I finally upgraded, I had my 68U running at 1.2/666 for over 6 years and never a hiccup with anything including OpenVPN. Secret to this which has gotten some heated discussions on this forum is having a fan blowing across the side of the unit. Bought a cheap desk fan with a clip at Walmart with 2 speeds, set it to lowest speed and voila CPU never went above 61C...usually in the range of 55-58C. Replaced the fan only once in all those years so Wally Mart makes a good product Noise can be annoying so placed the unit in a strategic closet within the house and range was never an issue in my home. Of course results may vary but without a doubt the best damn router I have ever owned period!Whether the AC68U can be overclocked under Asuswrt-Merlin and stock firmware depends on your hardware version and CFE version, only the old hardware and CFE version have the opportunity to overclock, newer models (such as those with 1 GHz (4708C0/4709A0/4709C0) upgrade model) will not be able to overclock, when you overclock, you will be forced to downclock to 100 MHz.
Overclocking the AC68U is a bad idea in my opinion, the performance gain is pretty insignificant unless you use OpenVPN, but the heat boost is so noticeable, you're speeding up your AC68U to death.
Welcome To SNBForums
