RT-AC68U FTP issues
ahasnaini
FTP server on AC68U is acting a bit weird.
1) Connecting for the first time always gives a timeout, but the second time it always connect.
Here is the log
Status: Connection established, waiting for welcome message...
Response: 220 Welcome to ASUS RT-AC68U FTP service.
Command: USER admin
Response: 331 Please specify the password.
Command: PASS ********
Response: 230 Login successful.
Command: SYST
Response: 215 UNIX Type: L8
Command: FEAT
Response: 211-Features:
Response: EPRT
Response: EPSV
Response: MDTM
Response: PASV
Response: ICNV
Response: REST STREAM
Response: SIZE
Response: TVFS
Response: UTF8
Response: 211 End
Command: OPTS UTF8 ON
Response: 200 Always in UTF8 mode.
Status: Connected
Status: Retrieving directory listing...
Command: PWD
Response: 257 "/"
Command: TYPE I
Response: 200 Switching to Binary mode.
Command: PASV
Error: Connection timed out
Error: Failed to retrieve directory listing
2) File transfer fails after a second or two
logs
Command: TYPE I
Command: PASV
Response: 227 Entering Passive Mode (31,48,190,241,121,142).
Command: RETR abc.mkv
Response: 0 Opening BINARY mode data connection for /tmp/mnt/ddrive/ddrive/M/B/abc.mkv (1464878889 bytes).
Error: File transfer failed after transferring 2369736 bytes in 2 seconds
Status: Starting download of /ddrive/ddrive/M/B/abc.mkv
Command: PASV
Response: 426 Failure writing network stream.
Command: PORT 192,168,2,105,212,117
I am running the lastest merlin beta 2
You're having a problem with passive mode. This usually indicates that your firewall hasn't been configured properly.
Also, I can see that you are connecting to your external (WAN) IP address. Is this intentional? Are you connecting from outside your LAN?
What happens if you connect locally? Your client appears to be on 192.168.2.105?
Enabling ports did make it work, is there a way to specify a range for ftp ports that will be used so I can enable them only
