Hello Everyone!
After days of tests I draw the conclusion that my old RT-AC68U running Merlin's 384.14_x firmware (earlier versions too, most probable) has a catastrophic bug in handling Dual WAN / Load Balance connections.
Bug reproduction parameters:
Bug circumventing:
- RT-AC68U router
- Merlin's 384.14_x firmware
- Dual WAN connection
- Load Balance dual WAN mode
- Ethernet or Wireless (2.4 or 5GHz) LAN connection
- Router's DHCP default parameters of the LAN connection
- Router's default routing rules (ESSENTIAL!!!)
Bug circumventing:
- make the device obtain a FIXED internal IP address
- set Router -> WAN -> Dual WAN -> Routing rules to route the above address to either Primary WAN or Secondary WAN, both IN and OUT
- allow router's DHCP to use a maximum range of 32 internal IP addresses to be assigned to the router's client devices
- in the dual WAN routing rules table, insert 32 pairs (IN and OUT) of routing rules for each of the above 32 internal IP addresses, to be routed towards either the Primary WAN or Secondary WAN (hence the 32 IP addresses limit: the table allows a maximum of 64 routing rules). NOTA BENE: using IP addresses ranges (192.168.0.0/29 or similar) in this table, although allowed by the router's entry form, is NOT functional (this may be another bug in the firmware!)
