Hi, how do I get mesh nodes to use different non-interfering channels?
I currently have one master and one slave mesh node. The master and slave node are both in AP mode.
I have a wired backhaul, Connection Priority" is set to Ethernet, Connection Type is "Wired".
If I set the channel to Auto the slave mesh node keeps picking the same channel as the master. Then the master keeps changing channels, possibly due to interference with the slave. The slave node then changes channels to follow the master... Rinse, repeat...
Each time the channels change, client connections get interrupted or dropped.
If I set the channel to a fixed channel the master and slave nodes use the same channel. This causes less disruption but seems suboptimal for performance.
