RT-AC68U, Merlin 378.56_2, Wrong clock behavior after factory reset.
MarkRH
The ASUS firmware also does this. After doing a Factory Reset, then setting the Timezone correct, not everything seems to be on the same clock. I turned on my blu-ray player and the System Log shows:
Nov  2 18:04:12 httpd: start httpd
Nov  2 18:04:12 miniupnpd[976]: could not open lease file: /var/lib/misc/upnp.leases
Nov  2 18:04:12 miniupnpd[976]: HTTP listening on port 57184
Nov  2 18:04:12 miniupnpd[976]: Listening for NAT-PMP/PCP traffic on port 5351
Nov  2 18:04:13 hour monitor: daemon is starting
Nov  2 18:04:51 dropbear[979]: Child connection from 192.168.1.184:64401
Nov  2 18:05:05 dropbear[979]: Password auth succeeded for '(removed)' from 192.168.1.184:64401
Nov  3 00:07:39 dnsmasq-dhcp[442]: DHCPDISCOVER(br0) (removed)
Nov  3 00:07:39 dnsmasq-dhcp[442]: DHCPOFFER(br0) 192.168.1.191 (removed)
Nov  3 00:07:39 dnsmasq-dhcp[442]: DHCPREQUEST(br0) 192.168.1.191 (removed)
Nov  3 00:07:39 dnsmasq-dhcp[442]: DHCPACK(br0) 192.168.1.191 (removed)
Notice how it thinks it connected on Nov 3rd like it's on UTC time. This also cause the daily traffic monitor to be thrown off as well. Doing the Date command via SSH shows the correct date.
@RT-AC68U-4D50:/tmp/home/root# date
Mon Nov  2 18:08:02 UTC 2015
Although, not sure if UTC is really correct. How would I make it be CST?
You must also configure the start/end time of DST, on the same page where you configured the timezone.
I did that when I set the Timezone because it though I was in Mountain time and not Central. Turned the blu-ray player on after I did that.
Changing the timezone might possibly not take full effect until reboot, as the router doesn't restart every single service when you change the timezone. The syslog server for instance might not get updated to the new timezone.
Yeah after Reboot all the clocks seem to match.
i have problem with wrong time in log.....how to solve this? using merlin 376.56_2 firmware....
Nov  6 15:08:15 dnscrypt-proxy[790]: Refetching server certificates
Nov  6 15:08:15 dnscrypt-proxy[790]: Server certificate #1435874751 received
Nov  6 15:08:15 dnscrypt-proxy[790]: This certificate looks valid
Nov  6 15:08:15 dnscrypt-proxy[790]: Chosen certificate #1435874751 is valid from [2015-07-03] to [2016-07-02]
Nov  6 15:08:15 dnscrypt-proxy[790]: Server key fingerprint is XXXXXXXXXXXXXXXXXXXXXXXXXXX
Nov  6 14:43:54 dnsmasq-dhcp[1123]: DHCPREQUEST(br0) 192.168.200.77
Nov  6 14:43:54 dnsmasq-dhcp[1123]: DHCPACK(br0) 192.168.200.77
Nov  6 14:44:20 dnsmasq-dhcp[1123]: DHCPREQUEST(br0) 192.168.200.153
Nov  6 14:44:20 dnsmasq-dhcp[1123]: DHCPACK(br0) 192.168.200.153 ASUS-Rog-PC
