RT-AC68U port forwarding issues
viper2059
I have been having issues of my port forwards not staying after hitting apply but if i enter them in a second time they will show on the list. If i close my router config after this and go back the ones i just entered no longer show. I had this issue first with build 376.45 and now updated to 376.48_1 and still have the same issue. I did not do a reset to default when updating to 376.48_1 but i did when i first installed 376.45. I also have NAT acceleration disabled.
Edit: I just checked the system logs for port forwards and shows the two i set up but they do not show in the port forwarding tab in the WAN section. Is this just a GUI glitch and should be fine?
My port forwards are now gone once again and not just from the port forwarding tab but from system log as well. Is this a known issue with Merlin builds?
If it's just a gui glitch then you should probably see them in vts_rulelist
nvram show |grep vts_rulelist
I don't know if it's a known issue or not, I'm on a ac68 with 374.43 fork and haven't had them disappear on me, in the gui or otherwise yet.
