RT-AC68U, samba, speed & CPU usage
bozho
Hi all,
Apologies if this has been answered elsewhere, but I'm having samba problems with a USB3 drive.
I'm using Merlin 380.59 on RT-AC68U. I have a 750 GB 2.5" drive plugged in using a USB3 enclosure (with a separate power supply) and shared using samba. The drive is formatted to EXT4.
Whenever I copy file to/from the drive (from a Win10 machine), top speed is ~25 MB/s and both router's cores are at ~100%.
I've tried things I found on this forum: disabling the "Reducing USB3 interference" option in the Wireless->Professional settings and reducing "Tx power adjustment" setting for both 2.4 and 5 GHz (and rebooting the router afterwards)
I've tried using a custom samba configuration using "use sendfile = no" with no effect. I'm sure that the custom config was used, since I changed one of the shares as well.
I've attached the generated smb.conf file.
Any ideas how to fix the problem?
Thank you.
what are you transferring to and from and how is it connected to the router
as 25MB/s is pretty good if its going to a device connected to the wifi and that device is 2 x 2 867M
also its best to use ether fat32 or ntfs for drives connected to the routers usb 3
these where my results with a ntfs formatted drive ,
USB 3 testing
usb3 to ethernet
read 52 MB/s write 38 Mb/s
usb 3 to asus pce-ac68 at 10 feet
read 33.5 Mb/s write 27.7 MB/s
usb 3 to belkin 1200 AC usb at 10 feet
read 23.5 MB/s 21.5 MB/s write
Of course I forgot something :-)
I tested with a large file (~2GB) from a machine with a wired connection.
I will try FAT32 and NTFS next.
How stable/safe is NTFS on Asus?
Thank you.
Ok, I've tried NTFS as well, same results (~25MB/s)
I've also plugged the drive+enclosure directly into the Win10 box, got around 100MB/s.
I'm guessing 25MB/s is AC68's maximum, considering both cores get to 100%...
I just plugged in a USB3 drive to my AC68U and got similar speeds like you.
Did you found any solution?
20-25Mb/s is far from the 50-60Mb/s some users reported.
Especially the 100% CPU load is strange. It doesn't matter if I copy via SMB, FTP or just format the drive from console...
The web front end is almost not responding during HD access. Probably due to the CPU load.
My old 1TB USB2.0 drive is faster (writing) then the new USB3.0 one.
The CPU load is slightly lower... how is that possible? Is this a bug?
I'm running the latest merlin build 380.63_2 for the ac68u.
Just for comparision I tried to connect my Sandisk USB3 Extreme 64GB thumb drive. Seams like it is not working at all. It didn't showed up...
Did you try fdisk /dev/sda (command line)? Then press P(show partitions). Are there any partitions?
The output is:
Command (m for help): p
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
   Device Boot      Start         End      Blocks  Id System
/dev/sda1               1      121601   976758815+  f Win95 Ext'd (LBA)
/dev/sda5               1      121601   976758784  83 Linux
I used mkfs.ext2 to format the drive yesterday. But I was quite sure there where no other partition yesterday..
Initially I used MiniPartition Wizard (on Win8.1) to create an ext3 partition..
Should I delete all partitions and just create one primary ext2/3/4 partition?
Damn. I mixed up the drives.
sda is the old USB2 drive. I attached the USB3 drive additionally today.
The ouput for the new drive is:
Disk /dev/sdb: 976746240 sectors, 3725G
Logical sector size: 4096
Disk identifier (GUID): e3c244c0-1e47-44d8-8861-9810a2532b7b
Partition table holds up to 128 entries
First usable sector is 6, last usable sector is 976746234
Number  Start (sector)    End (sector)  Size       Code  Name
   1             256       976735743       3725G   0700  Basic data partition
I was right. Just one partition..
I should remove all partition. Then create a new linux partition with ext2 filesystem. Then it should show up.
I removed the partitions.
I used 'o' (fdisk) to create a new empty DOS partition table.
I created a new primary partition. Assigned the complete size of the drive.
I formated with mkfs.ext4.
Disk mounts. BUT I can't create shareable folders in the UI.
The radio buttons are missing. I just see a dotted line.
According to a thread I found here at the forum. Merlin mentioned that it is a bug. What is a 'valid' partition table?
Mine looks right now like this:
Disk /dev/sdb: 4000.7 GB, 4000752599040 bytes
256 heads, 63 sectors/track, 60562 cylinders
Units = cylinders of 16128 * 4096 = 66060288 bytes
/dev/sdb1               1       60562  3906975492  83 Linux
I didn't had this issues with the "Mini Partition Wizard" partitioned drive...
Very strange!
Very strange!
You should NOT use 'o', but n (create new partition). Type should be linux. For usb thumb drives better choose ext2. (Less overhead)
After formatting, maybe need te re-plug the drive to show up
'o' just deletes the partition table by overwriting it with an empty one. Or did I missed something?
It is a hard drive not a thumb drive. It is a 4TB drive.
What should be used? MBR or GPT?
What partition type? primary? extended?
The drive shows up. But I can't create folder within the Web UI to share them as FTP or SMB shares. I can create folders on command line and they show up. But I can't set the permissions nor delete them from the WEB UI.
O creates a DOS partition table:
Command (m for help): m
Command Action
a toggle a bootable flag
b edit bsd disklabel
c toggle the dos compatibility flag
d delete a partition
l list known partition types
n add a new partition
p print the partition table
q quit without saving changes
s create a new empty Sun disklabel
t change a partition's system id
u change display/entry units
v verify the partition table
w write table to disk and exit
x extra functionality (experts only)
So delete the current partition with d. Then create a new partition with n. Type linux(83). Then use ext2/ext3 or ext4. Whatever you like.
I've seen this happen when the drive is connected via a USB hub. If you are using a hub, try direct pluging the drive.
No hub. USB 3.0 drive connected to USB3 port.
USB 2.0 drive connected to USB2 port.
I can't delete the existing partition on the drive. I just can' be deleted. Any ideas?
I suspect fdisk is not working correctly with 4TB drives (GPT).
Alright. I just used 'o'
Seams like it is the only way to clear the partition table.
Now I will try an extended partition with one logic one inside.
Let's hope the best...
That explains some of the problems and why it worked with MiniTool Partition Wizard.
Too bad fdisk doesn't give any hint on that limitation or any error messages.
To format a 4TB drive with ext3/4 takes forever. I really hope it will become better with an extended partition, like with my old 1TB drive.
But to be honest. I already lost most of my confidence that it will work decently...
Seams like the AC68u and USB3 is a bad idea..
