Haraldinho
My Asus RT-AC68U works fine, I really love it. However, in the past months I have noticed that the router gets slower and slower every day. After I reboot the router, it is back at its normal speed.
The slowness typically shows when surfing the web from iPad or iPhone. When I do a speedtest during these slow performance periods, it nicely shows the normal speed (100 Mbit up and down through fibre). Restarting the iPhone and iPads does not change anything.
I know it is possible to automatically restart the router regularly, but as I have security cameras attached to it, that is not really an option.
I use Merlin 380.59. My setup is two cable connected RT-AC68U routers, one in router mode, one in Access Point mode.
I have two questions for the community:
1) does anybody recognize this issue and is there something that I can do to fix it?
2) if there is no fix, is there a way I can analyze the network behavior to figure out what is causing the slowness?
Thanks!
Thanks!
