vmaul
Hello all,
I've had an RT-AC68U for about 3 years and in the last few months I've been having a steadily increasing number of internet drop-outs while working on my PC.
First I thought it was my powerline connectors, as I could unplug and replug network cables and it would almost always come back online. Figured it was decaying Devolo units, so...
After replacing my powerline plugs, it seems I might be wrong; this "unplug/replug fix" no longer works, too, the internet connection drops and doesn't come back.
Connecting to the router over wireless I can watch all the ethernet clients vanish. Then, if I wait 20 seconds, the connection over wireless goes sour. Then basically it's power-cycle time for the RT-AC68U, and things are back to normal.
I confirmed that it wasn't still some powerline glitch by trying to connect to PSN on the PS4, which is wired in directly to the router - no dice.
Last time it happened I had the Merlin perf tuning open on the PC .. nothing unusual in the temperatures (you can see it flatline - https://i.imgur.com/6piDm9T.png) .. and nothing in the system logs even close to the time it dies.
I did a full factory reset + nvram clear when I installed Merlin (and set up from scratch, no re-importing). Didn't help.
Anyone have any insights or other things to check? Time to replace the router and see what breaks next?
