RT-AC68U - Video streaming fails in after some minutes in my Home theater
Prakash K
Video streaming fails in after some minutes in my LG Home theater. It fails at different duration at different instances - 5 mins or 20 mins or 40 mins after start of video streaming - no defined pattern.
Few times, the home theater gets disconnected from the router and gets connected automatically - noticed the the router icon disappearing and appearing again.
In both instances, I ended-up selecting the file to start streaming again. Sometimes it happens 3 or 4 interruptions in 60 minute video and worse in few other times - 10 interruptions in 60 minutes.
The was working without any problem prior to version - 3.0.0.4.378.9135 - Issue started from this version.
Firmware - Official. Updated to 3.0.0.4.378.9313, but the issue persists still.
Any one facing the same issue ?
Please guide me to solve the issue.
When you updated firmware, did you Factory Reset afterwards, then manually restore your configuration? Or did you restore settings from a config file saved previously?
Are you wired or wifi? I am wired. I have a WDTV box that has been locking up on me for the past 3 weeks with the 9135 fw and still with the 9313. Did a factory reset but cant tell if its the WDTV box or the asus FW. The box totally locks and I have to cycle power.
