lucidry
Hi Folks,
I am a novice when it comes to setting up VPN, configuring keys, routing, etc.
I have sort-of gotten the OpenVPN working, using the 'Export OpenVPN configuration file' I have tested connectivity with OpenVPN connect on Android (importing the ovpn file) and as well from a Windows machine at work (using OpenVPN gui), they connect and show up on my router's 'VPN Status' page when connected. (it is set with default vpn ip of 10.8.0.x)
However, I am unable to really access anything LAN related. I can't ping any of my machines (192.168.1.x) from the Windows machine, nor can I ping the assigned IP 10.8.0.6 from the windows machine (I can however ping 10.8.0.1)
And no local resources seem available. I cannot connect to any samba shares from the vpn'd windows machine.
I have also gone through the easy-rsa key generation process.. I havn't put those entries into the 'Content modifications of keys & certificates' section yet though as I'm just testing it out with the auto-generated ovpn and trying to ensure I have full LAN connectivity including samba shares and what not.
(--- when i do eventually plop those entries into those fields, will the ovpn file generated list the different .key and .crt files in there automatically or do you have to manually edit the ovpn file? ---)
Some of the reading online suggests some IP forwarding and static routes that need to be inputted, and yet other threads I've read suggest it should just work.
I have disabled windows firewall on both of the machines (windows side behind the 192.168.1.x subnet, and the vpn'ing in windows machine with the 10.8.0.6 address)
Here are my settings:
VPN Details tab:
VPN server mode: OpenVPN
Select server instance: Server 1
Interface type: TUN
Protocol: UDP
server port: 1194
Firewall: Auto
Authorization mode: TLS
username/password authentication: No
Extra HMAC: Disable
VPN Subnet/Netmask 10.8.0.0 255.255.255.0
poll interval: 0
Push Lan to clients: yes
direct clients to redirect internet traffic: no
respond to dns: no
encryption cipher: AES-256-CBC
compression: adaptive
tls renegotiation time: -1
maanage client-specific options: no
------------- EDIT ----------
sorry, i wrote the wrong IP, at one point i'd tried changing from 10.8 to 192.168.8 for testing..
at one point i was able to connect to \\10.8.0.6\c$ as well as ping, from my windows machine on the 192.168.x but only once among my testing, havn't been able to do that again...
Anyone who can point me in the right direction, it would be appreciated.
VPN Details tab:
Interface type: TUN
Protocol: UDP
server port: 1194
Firewall: Auto
Extra HMAC: Disable
poll interval: 0
respond to dns: no
