RT-AC68U: WebUI SSL Certificate Issue
Mode
Hi All,
Has been using the WebUI SSL certificate to configure the SSL login to router for some time. However today my SSL from Letsencrypt about to expire and decided to renew it. Same process to renew it which i've been doing it for 1 year.
But when i went into the router's Administration page --> DDNS page then select "Import/Persistent Auto-generated" and uploaded my cert & private key cert and clicked apply ("Generate a new certificate"option NO).
Now the issue is it did not uploaded my both files but instead router generate both self signed cert & private key.
Router Model: RT-AC68U
Firmware version: 384.13_0
SSL Certificate used: Letsencrypt
Log file:
Aug 16 12:07:09 httpd: Failed to initialize SSL, generating new key/cert.
Aug 16 12:07:10 httpd: Generating SSL certificate...
Hope anybody can give a clue on how to solve the above issue.
Many Thanks
Mode
That would indicate either a problem with the format of the key/cert you uploaded, or they did not match.
Hi RMerlin,
Your comment indeed is correct, got the prv key mixed up.
Thanks, problem solved.
Mode
