learning_curve
As per the thread title really; ddns is NOT enabled on the GUI page; /Advanced_ASUSDDNS_Content.asp on this router, yet, every ten minutes; this 2 line script runs:
Everything else runs perfectly, with no other errors or similar restarts etc including, IPv6, which although it has a static IPv6 address from the service provider, it's setup with a Native connection type & a PPP Interface on this page: /Advanced_IPv6_Content.asp because, having perviously experimented with both, it works much better this way with this specific service provider! The excellent jackyaz/YazDHCP from @Jack Yaz is used for DHCP / Static Addresses but reasonably sure that's not a contributory factor in this case. First guess is... that this might need a small config change somewhere within this file: ./tmp/etc/dnsmasq.conf but that might be completely wrong and the not my 1st choice option of a factory reset / re-config might be the only answer. Anybody have a clearer insight / previous experience / know how to fix for this? There are lots of threads with pretty similar, but not exactly the same content (that I've seen do far anyway).Feb 4 16:26:30 rc_service: dhcp6c 16211:notify_rc restart_ddns
Feb 4 16:26:30 custom_script: Running /jffs/scripts/service-event (args: restart ddns)
