RT-AC86U AiMesh ASUSWRT-Merlin
Skeptical.me
I'm trying to find how to enable AiMesh on my 86U that has ASUSWRT-Merlin on it, but I'm having no success.
Does the Merlin firmware disable AiMesh? If not how can I enable it?
AIMesh not supported by Merlin. It won't be supported anytime soon.
ahh, what a shame. Okay. Thanks for the information.
Compulsory link to: https://www.snbforums.com/threads/faq-read-me-first-before-posting-a-question.47153/
Q: Will Asuswrt-Merlin support AiMesh?
A: Highly unlikely, due to technical limitations caused by incompatibilities between my code, and Asus's closed source components for AiMesh.
Hi.
I am running main router ac86u (384.13 merlin) on which I disabled 2.4 GHz band. However on my ac68u aimesh node (latest official asuswrt) the 2.4 GHz band is still on. Since there is no real way to control the node is there a way to turn off the 2.4 GHz band on the node?
yes, you could do using SSH, search for command to turn off 2.4G (or look which NVRAM paramter changes if you turn off 2.4G).
Could be something like: nvram set wl0_radio=0 && nvram commit
AIMesh not supported by Merlin. It won't be supported anytime SOON.
My RT-AC68R flashed with Merlin has AIMesh support. When did Merlin start supporting AIMesh? Was it SOON after your post? ;) LOL
@g725s, you're quoting @skeal from a year and a half ago. :rolleyes::oops::D:p
