maxime
Hi to everybody!
I've two FTTH Lines connected to my RT-AC86U:
- Line1 (1Gbit/300Mbit) set as primary, Wan (PPOE) direct connected to the ISP's Ont
- Line2 (1Gbit/1Gbit) set ad secondary, Lan connected to a FritzBox! Router (connected to the secondary ISP's Ont)
I've some problem using dual Wan load balancing: delays browsing internet, timeout pages loading, Google Home is unusable, skype or whatsapp call problems, etc...
I solved using manual routing rules, assigning every IP to a specific wan, but it's very boring and it's loophole, not a solution: a working load balancing doesn't require manual routing rules!
I found there was an old post talking about this problem, and it was opened on 2017! No yet solution to the problem from Merlin after 5 years?
Thanks for the support!
