RT-AC86u can't turn off LED
VANT
Hi.
In latest FW i cant turn off LED using Led On/Off buttons. I have latest FW.
In earlier FW this work ok, now not.
Can anyone confirm this ?
best regards
VANT
edit.
after router restart, led on/off start working ok.
Ssame here on old firmware 7743. Did you tried to hold the button more than 3 secs?
yes i press 3s, not help. only reboot router help.
Hi VANT,
My RT-AC86U update FW 3.0.0.384.20308 cannot duplicate same issue, could you tell me your router set which service or provide router setting file??
Hi Bruce_Chin
Now, after router restart, led on/off switch work ok. I try after more router uptime.
Setting file ? But i do not know you.
Hi Bruce_Chin
If the led on/off still doesn't work, could you send feedback with your cfg file by Feedback function ? I will pass it to internal team.
Now works, ok, as i writre earlier, i will check again after more router uptime.
btw.
IMO
It would be good to add, led on/off switch and scheduler to gui.
btw.
IMO
I suggest you send feedback with your suggestion by feedback function, someone will collect it.
