So I have recently purchased an RT-AC86U to replace my ageing RT-AC68U as I now have 30+ devices connected to my network and the 68U was starting to show its age a little bit (sometimes devices were sluggish, and a couple if times it locked up completely requiring a full power off and on)
The RT-AC86U is a very fast and capable router and adaptive QOS works a treat on it when compared to the older 68U, however I have noticed an odd issue on the 86U though and its that it wont hold on to the DFS channels always dropping back to channel 48.
On my 68U it practically lived on channel 100 all the time, and because every other wifi system in my local vicinity is ISP provided I was the only one using the DFS channels and it worked awesome With very good range. However on the 86U it chooses channel 108 and holds it for a random amount of time then will drop to 48 and never return back to 108. I know on DFS channels routers are meant to vacate a DFS channel when radar is detected but after 30 minutes they can return back, however the 86U never returns.
Normally I wouldn’t be fussed as wifi performance is still very decent however in my daughters bedroom its where you notice the change the most. When using DFS channels the routers can increase their transmit power and the difference is that on channels 100/108 the iDevices will sit on full wifi signal all the time rather than dropping to 2 bars and her Nintendo Switch will sit between 2-3 bars signal rather than 1-2 bars on channel 48.
My question is is this normal behaviour for the 86U I do live near a small airfield so radar would likely be detected, however I find it odd that the 68U didn’t release channel 100 yet the 86U wont stay on it for long. Is it because the 86U has a more sensitive antenna setup and is likely detecting radar that the 68U likely didn’t detect? Or do I have a faulty unit? Or is this just how the newer Asus Routers handle DFS channels?
