Skeptical.me
In the past I've been using the solution found in this post https://www.snbforums.com/threads/cant-get-openvpn-using-expressvpn-to-run-on-rt-ac86u.48599/ in order to get ExpressVPN working in an OpenVPN Client on my RT-AC86U Merlin (Currently 384.8_2).
However, recently every time I use the OpenVPN Client with ExpressVPN rather than seeing 1 DNS server I am seeing 12. I do not have the DNSFilter enabled, nor do I have any DNS addresses input into LAN>DHCP SERVER>DNS & WIN SERVER SETTING>DNS 1>DNS 2
Furthermore, my internet connection frequently drops in and out, and when this occurs I'm unable to access the internet at times. This does not occur at all on Client number 3 using ProtonVPN .ovpn Config. ProtonVPN is working perfectly well.
Here are the settings for OpenVPN Client 2:
Here is the full Custom Configuration:
And here are the logs:
I hope someone has the time to have a quick look and give some advice about how to resolve this issue. I appreciate every one who takes a look, thank you.
fast-io
remote-random
pull
tls-client
verify-x509-name Server name-prefix
ns-cert-type server
route-method exe
route-delay 2
tun-mtu 1500
fragment 1300
mssfix 1450
keysize 256
sndbuf 524288
rcvbuf 524288
comp-lzo no
push "comp-lzo no"
Dec 27 04:44:42 rc_service: httpds 825:notify_rc stop_vpnclient2
Dec 27 04:44:42 ovpn-client2[3306]: event_wait : Interrupted system call (code=4)
Dec 27 04:44:42 ovpn-client2[3306]: vpnrouting.sh tun12 1500 1557 10.165.0.66 10.165.0.65 init
Dec 27 05:44:42 openvpn-routing: Configuring policy rules for client 2
Dec 27 05:44:42 openvpn-routing: Tunnel down - VPN client access blocked
Dec 27 04:44:42 ovpn-client2[3306]: /bin/ip route del 10.165.0.1/32
Dec 27 04:44:42 ovpn-client2[3306]: ERROR: Linux route delete command failed: external program exited with error status: 2
Dec 27 04:44:42 ovpn-client2[3306]: /bin/ip route del 45.56.XXX.XX/32
Dec 27 04:44:42 ovpn-client2[3306]: /bin/ip route del 0.0.0.0/1
Dec 27 04:44:42 ovpn-client2[3306]: /bin/ip route del 128.0.0.0/1
Dec 27 04:44:42 ovpn-client2[3306]: Closing TUN/TAP interface
Dec 27 04:44:42 ovpn-client2[3306]: /bin/ip addr del dev tun12 local 10.165.0.66 peer 10.165.0.65
Dec 27 04:44:42 ovpn-client2[3306]: updown.sh tun12 1500 1557 10.165.0.66 10.165.0.65 init
Dec 27 05:44:42 rc_service: service 7320:notify_rc updateresolv
Dec 27 05:44:42 rc_service: waitting "stop_vpnclient2" via httpds ...
Dec 27 04:45:02 rc_service: httpds 825:notify_rc start_vpnclient2
Dec 27 04:45:02 ovpn-client2[7452]: WARNING: --keysize is DEPRECATED and will be removed in OpenVPN 2.6
Dec 27 04:45:02 ovpn-client2[7452]: OpenVPN 2.4.6 arm-buildroot-linux-gnueabi [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Dec 8 2018
Dec 27 04:45:02 ovpn-client2[7452]: library versions: OpenSSL 1.0.2q 20 Nov 2018, LZO 2.08
Dec 27 04:45:02 ovpn-client2[7453]: WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Dec 27 04:45:02 ovpn-client2[7453]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Dec 27 04:45:02 ovpn-client2[7453]: Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Dec 27 04:45:02 ovpn-client2[7453]: Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Dec 27 04:45:04 ovpn-client2[7453]: TCP/UDP: Preserving recently used remote address: [AF_INET]45.56.XXX.XX:1195
Dec 27 04:45:04 ovpn-client2[7453]: Socket Buffers: R=[524288->1048576] S=[524288->1048576]
Dec 27 04:45:04 ovpn-client2[7453]: UDP link local: (not bound)
Dec 27 04:45:04 ovpn-client2[7453]: UDP link remote: [AF_INET]45.56.XXX.XX:1195
Dec 27 04:45:04 ovpn-client2[7453]: TLS: Initial packet from [AF_INET]45.56.XXX.XX:1195, sid=72a1e662 18048126
Dec 27 04:45:04 ovpn-client2[7453]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Dec 27 04:45:04 ovpn-client2[7453]: VERIFY OK: depth=1, C=VG, ST=BVI, O=ExpressVPN, OU=ExpressVPN, CN=ExpressVPN CA, emailAddress=support@expressvpn.com
Dec 27 04:45:04 ovpn-client2[7453]: VERIFY OK: nsCertType=SERVER
Dec 27 04:45:04 ovpn-client2[7453]: VERIFY X509NAME OK: C=VG, ST=BVI, O=ExpressVPN, OU=ExpressVPN, CN=Server-CCC-CC, emailAddress=support@expressvpn.com
Dec 27 04:45:04 ovpn-client2[7453]: VERIFY OK: depth=0, C=VG, ST=BVI, O=ExpressVPN, OU=ExpressVPN, CN=Server-CCC-CC, emailAddress=support@expressvpn.com
Dec 27 04:45:05 ovpn-client2[7453]: Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 2048 bit RSA
Dec 27 04:45:05 ovpn-client2[7453]: [Server-CCC-CC] Peer Connection Initiated with [AF_INET]45.56.XXX.XX:1195
Dec 27 04:45:06 ovpn-client2[7453]: SENT CONTROL [Server-CCC-CC]: 'PUSH_REQUEST' (status=1)
Dec 27 04:45:06 ovpn-client2[7453]: PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.114.0.1,route 10.114.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.114.0.XXX 10.114.0.XXX,peer-id 59,cipher AES-256-GCM'
Dec 27 04:45:06 ovpn-client2[7453]: OPTIONS IMPORT: timers and/or timeouts modified
Dec 27 04:45:06 ovpn-client2[7453]: OPTIONS IMPORT: --ifconfig/up options modified
Dec 27 04:45:06 ovpn-client2[7453]: OPTIONS IMPORT: route options modified
Dec 27 04:45:06 ovpn-client2[7453]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Dec 27 04:45:06 ovpn-client2[7453]: OPTIONS IMPORT: peer-id set
Dec 27 04:45:06 ovpn-client2[7453]: OPTIONS IMPORT: adjusting link_mtu to 1629
Dec 27 04:45:06 ovpn-client2[7453]: OPTIONS IMPORT: data channel crypto options modified
Dec 27 04:45:06 ovpn-client2[7453]: Data Channel: using negotiated cipher 'AES-256-GCM'
Dec 27 04:45:06 ovpn-client2[7453]: NCP: overriding user-set keysize with default
Dec 27 04:45:06 ovpn-client2[7453]: Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Dec 27 04:45:06 ovpn-client2[7453]: Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Dec 27 04:45:06 ovpn-client2[7453]: TUN/TAP device tun12 opened
Dec 27 04:45:06 ovpn-client2[7453]: TUN/TAP TX queue length set to 100
Dec 27 04:45:06 ovpn-client2[7453]: do_ifconfig, tt->did_ifconfig_ipv6_setup=0
Dec 27 04:45:06 ovpn-client2[7453]: /bin/ip link set dev tun12 up mtu 1500
Dec 27 04:45:06 ovpn-client2[7453]: /bin/ip addr add dev tun12 local 10.114.0.242 peer 10.114.0.241
Dec 27 04:45:06 ovpn-client2[7453]: updown.sh tun12 1500 1557 10.114.0.242 10.114.0.241 init
Dec 27 05:45:06 openvpn-updown: Forcing 192.168.1.150 to use DNS server 10.114.0.1
Dec 27 05:45:06 openvpn-updown: Forcing 192.168.1.196 to use DNS server 10.114.0.1
Dec 27 05:45:06 openvpn-updown: Forcing 192.168.1.85 to use DNS server 10.114.0.1
Dec 27 05:45:06 openvpn-updown: Forcing 192.168.1.112 to use DNS server 10.114.0.1
Dec 27 05:45:06 openvpn-updown: Forcing 192.168.1.248 to use DNS server 10.114.0.1
Dec 27 05:45:06 openvpn-updown: Forcing 192.168.1.151 to use DNS server 10.114.0.1
Dec 27 05:45:06 openvpn-updown: Forcing 192.168.1.219 to use DNS server 10.114.0.1
Dec 27 05:45:06 openvpn-updown: Forcing 192.168.1.227 to use DNS server 10.114.0.1
Dec 27 05:45:06 openvpn-updown: Forcing 192.168.1.234 to use DNS server 10.114.0.1
Dec 27 05:45:06 openvpn-updown: Forcing 192.168.1.247 to use DNS server 10.114.0.1
Dec 27 05:45:06 rc_service: service 7669:notify_rc updateresolv
Dec 27 04:45:08 ovpn-client2[7453]: /bin/ip route add 45.56.XXX.XX/32 via 203.40.255.XXX
Dec 27 04:45:08 ovpn-client2[7453]: /bin/ip route add 0.0.0.0/1 via 10.114.0.241
Dec 27 04:45:08 ovpn-client2[7453]: /bin/ip route add 128.0.0.0/1 via 10.114.0.XXX
Dec 27 04:45:08 ovpn-client2[7453]: /bin/ip route add 10.114.0.1/32 via 10.114.0.XXX
Dec 27 05:45:08 openvpn-routing: Configuring policy rules for client 2
Dec 27 05:45:08 openvpn-routing: Tunnel re-established, restoring WAN access to clients
Dec 27 04:45:08 ovpn-client2[7453]: Initialization Sequence Completed
