Rt ac86u factory reset
bobpow
i am looking all over the GUI but I cannot find reset to factory defaults on the
RT 86u
Thanks in advance
thanks , I looked at it 5 times and missed it , these old eyes are getting tired
better use WPS button while powering on, often works much better than software reset.
You may find the following links useful. :)
M&M Config https://www.snbforums.com/threads/n...l-and-manual-configuration.27115/#post-205573
WPS NVRAM Erase https://www.snbforums.com/threads/b...eta-is-now-available.55520/page-9#post-473141
Sanitize Network https://www.snbforums.com/threads/rt-ac66u-slow-wan-to-lan.12973/page-3#post-269410
Control Channel Set up https://www.snbforums.com/threads/a...details-in-the-description.55582/#post-472051
amtm Step-by-Step https://www.snbforums.com/threads/amtm-step-by-step-install-guide-l-ld.56237/#post-483421
The first four will get your router to a good/known state. Once it's there, the last link will give your router superpowers you never knew it had! :)
Okay, it will at least let you use a spare USB drive as a swap file. But it can offer much more too. :)
