Netachi
Hello. I have an Asus RT-AC86U running Asus Merlin firmware 386.12. It is currently running in access point mode (Main router upstairs this one is just an AP for downstairs.) and I have run into a weird issue that has been ongoing.
I utilize a 2.4ghz guest network for all my Internet of Things devices such as lights, the garage, and Google Home systems et cetera. I transitioned from a RT-AC66U in this same scenario and never had any issues however I thought since that router was meeting end of life and merlin support, I would upgrade to the AC86U and that should be good for some time moving forward. The issue I'm running into is that every other day or even every few hours all the devices on the guest network will not be able to connect to the RT-AC86U and I can’t use them. The router is still broadcasting the guest network however when I try to connect to the network even my phone is refused connection and will say connection failed.
After doing some research it seemed initially that there was some discussion not to use slot 1 under the guest network section under 2.4ghz as there were various issues arising with that. I’ve tried moving the network from slot 1,2, and 3 with the same issue arising. To remedy the issue for a while, I then have to reboot the router and then the guest network will work for a little while, but the issue will always arise again. As a small workaround I then had to schedule the router to reboot every night, but the issue is becoming more and more frequent. What strikes me as weird however is that the regular 2.4 gigahertz network as well as 5 gigahertz networks on the same device seems to function fine without issue and I've never ran into this issue. I'm trying to isolate and see what could really cause this issue and has anyone seen this before. As you know many of the Internet off thing devices only support 2.4ghz. I would also rather they not be on my main network hence why I’m using the guest network. Any tips or advice is appreciated.
