RT-AC86U kernel error message
Hawk
Nov 23 12:41:58 kernel: nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
Nov 23 12:45:11 kernel: jffs2: warning: (718) jffs2_sum_write_data: Not enough space for summary, padsize = -49
I am getting these error message on 382.1 Merlin version, does anyone aware of this error message and possible cause.
I am getting this error too on RT-AC86U running Merlin 384.4_beta2
Mar 9 20:10:46 kernel: nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
Mar 9 20:11:14 kernel: br0: received packet on eth5 with own address as source address
Does anyone know a possible cause of this error? I have fairly simple setup with just VPN running. I did not change anything except setting WiFi, binding one device IP and changing DHCP pool ip start...
Try deleting the traffic.db database generated by Traffic Analyzer - it might have grown too large. I know Asus implemented some size control a year or two ago, but maybe the file still manages to get too large.
Both of those messages are informational not errors. They are not connected to each other or the warning about jffs in the OP.
