Fr4ncis
First of all, I love the AC86U and AsusWRT Merlin - amazing piece of software!
I experience a very odd issue - it happened even before 386.1 and I cannot root-cause it (factory reset with the various methods tried as well). It seems devices connect to the wifi network at 2.4GHz "MaisonSmith" but then some of the devices complain they cannot connect to the Internet. If I connect them to the 5GHz network "MaisonSmith 5GHz" they work fine.
In reality, ping apps on those devices work fine within the network and to the Internet (e.g. maya.ngi.it) but the system still believes they're not connected (outcome is that browser and other apps do not work at all) and this is a bigger issue for light switches connected to 2.4GHz which randomly stop to work. From the router perspective it seems the devices are connected fine to the network. It almost seems like the network is not working very well which makes some devices struggle to realise they're connected to Internet.
It does not even seem to be a problem with congestion or bad channel selection - any advice?
Thank you!
The devices MAC addresses with problems from the tests were:
12:7B:69:EE:E7:0F (phone)
74:58:F3:A5:BD:99 (tablet)
Wireless logs
Thank you!
Wireless logs
SSID: "MaisonSmith"
noise: -87 dBm Channel: 6
BSSID: 04:D4:C4:1B:D6:38 Capability: ESS RRM
Supported Rates: [ 1(b) 2(b) 5.5(b) 6 9 11(b) 12 18 24 36 48 54 ]
VHT Capable:
Chanspec: 2.4GHz channel 6 20MHz (0x1006)
Primary channel: 6
HT Capabilities:
Supported HT MCS : 0-23
Supported VHT MCS:
NSS1 Tx: 0-11 Rx: 0-11
NSS2 Tx: 0-11 Rx: 0-11
NSS3 Tx: 0-11 Rx: 0-11
Interference Level: Acceptable
Mode : AP Only
Stations List
idx MAC Associated Authorized RSSI PHY PSM SGI STBC MUBF NSS Tx rate Rx rate Connect Time
0E:FC:E0:5F:9D:72 Yes -82dBm n Yes Yes Yes No 2 1M 1M 00:00:07
12:7B:69:EE:E7:0F Yes Yes -42dBm ac Yes Yes No No 2 192.5M 1M 00:01:37
74:58:F3:A5:BD:99 Yes Yes -46dBm n Yes Yes Yes No 1 72.2M 1M 00:03:12
B0:5A:DA:67:75:F1 Yes Yes -67dBm n No Yes No No 1 65M 216.7M 00:16:49
FC:49:2D:0E:12:11 Yes Yes -58dBm n Yes Yes Yes No 1 65M 1M 02:02:53
28:18:78:63:DA:83 Yes Yes -63dBm n No Yes Yes No 2 115.6M 1M 03:05:09
DC:4F:22:E2:A2:97 Yes Yes -46dBm n Yes Yes Yes No 1 72.2M 6M 03:30:33
60:01:94:86:57:46 Yes Yes -38dBm n Yes Yes Yes No 1 72.2M 6M 03:30:33
60:01:94:97:EF:6D Yes Yes -43dBm n No Yes Yes No 1 65M 54M 03:30:49
50:C7:BF:27:F5:B1 Yes Yes -46dBm n No Yes Yes No 1 65M 1M 03:30:51
68:DB:F5:05:16:29 Yes Yes -55dBm n No Yes Yes No 2 144.4M 144.4M 03:30:55
1C:12:B0:B1:3F:6D Yes Yes -44dBm n No Yes Yes No 1 72.2M 72.2M 03:30:56
B0:95:75:F8:28:38 Yes Yes -65dBm n No Yes Yes No 3 216.7M 216.7M 03:31:07
SSID: "MaisonSmith 5GHz"
noise: -87 dBm Channel: 112/80
BSSID: 04:D4:C4:1B:D6:3C Capability: ESS RRM
Supported Rates: [ 6(b) 9 12(b) 18 24(b) 36 48 54 ]
VHT Capable:
Chanspec: 5GHz channel 106 80MHz (0xe36a)
Primary channel: 112
HT Capabilities:
Supported HT MCS : 0-31
Supported VHT MCS:
NSS4 Tx: 0-11 Rx: 0-11
Mode : AP Only
DFS status: state In-Service Monitoring (ISM) time elapsed 12623700ms radar channel cleared by DFS channel 112/80 (0xE36A)
Channel Information
Channel 36 A Band
Channel 40 A Band
Channel 44 A Band
Channel 48 A Band
Channel 52 A Band, RADAR Sensitive, Passive
Channel 56 A Band, RADAR Sensitive, Passive
Channel 60 A Band, RADAR Sensitive, Passive
Channel 64 A Band, RADAR Sensitive, Passive
Channel 100 A Band, RADAR Sensitive
Channel 104 A Band, RADAR Sensitive
Channel 108 A Band, RADAR Sensitive
Channel 112 A Band, RADAR Sensitive
Channel 116 A Band, RADAR Sensitive, Passive
Channel 132 A Band, RADAR Sensitive, Passive
Channel 136 A Band, RADAR Sensitive, Passive
Channel 140 A Band, RADAR Sensitive, Passive
Stations List
B8:5F:98:8A:2E:89 Yes Yes -51dBm ac Yes Yes Yes Yes 2 702M 6M 03:29:25
F0:18:98:4D:90:29 Yes Yes -54dBm ac No Yes Yes No 3 1170M 1300M 03:30:06
48:43:DD:5F:3E:7F Yes Yes -56dBm ac Yes Yes Yes Yes 1 390M 6M 03:30:17
10:96:93:72:C1:00 Yes Yes -51dBm ac No Yes Yes Yes 2 866.7M 6M 03:30:19
