RT-AC86U no open ports - all ports forwarded on WAN access device
zd59
Hi!
My configuration:
WAN/Internet access Cisco EPC3928S router, NAT, all ports forwarded.
RT-AC86U with Merlin FW 384.11_2, connected to above Cisco on LAN port .
All devices on a local network can access Internet and can SSH to RT-AC86U or its WEB GUI.
For SSH I have my own key pair and connects from LAN. (password logon disabled)
But RT-AC86U is invisible from internet. Only ping works. SSH do not work, but in settings is "SSH access" "LAN and WAN" All other network settings are default, except uPNP is off for security reasons.
nmap port scanner with -p- option returns:
Nmap done: 1 IP address (0 hosts up) scanned in 3.04 seconds
How to set things so that RT-AC86U will be accessible from WAN?
I need SSH & OpenVPN from internet.
Also pointing out that previously I had Netgear R7500 WiFi router and Asus RT-AC86U is direct replacement.
With Netgear all worked, SSH to it and OpenVPN to LAN both from Internet. So Cisco connected to WAN correctly forward ports. The reason must be on Asus RT-AC86U.
Check your modem. Maybe its forwards were set to a different IP address than with the Asus.
Thank you RMerlin.
I was planing to check Cisco settings today after return home. That was before you answered here.
Success :) - the reason:
I've set up a static IP regarding to MAC of my previous router (Netgear) and this was in DMZ.
After replacing MAC with current Asus WAN port MAC, on Cisco, Asus is visible on internet.
Checked with phone on cellular network, and it successfully connect SSH with prvate key to my Asus AC-RT86U.
p.s.: your job is excellent. :) Flashed Merlin FW on fresh Asus from store.
