bubobih
Hello, im using asus merlin for a long time. so i notice 2 problems for a while but i didnt post here beacuse i didnt have time..
1st wifi slow
- 50/50 is over wifi im 20cm from router.... before it was 70 80 100 /50... so some update broke that thing... i do factory, i restore orginal asus then again factory and problem was fixed. i do asus merlin and factory, problem agian 50/50. i try everything disable 5ghz switch any command reboots change channels nothing helps... and i know that before it was 100/50 in my case....
2.ssh thats problem for a while too, every time i try even after this few factory i try it every time and i get this
http://prntscr.com/onnpwc
1st wifi slow
