I seem to be having exactly the same problem described above. I am using a RT-AC86U router and am the only client on the 5 GHz wifi, the other. clients are on 2.4Ghz.
I get get pretty regular ping spikes on the 5GHz wifi which make playing online games impossible. I know, for sure, that it is not my ISP as plugging in a LAN cable or using the already congested 2.4GHz channel works fine without any issues.
Here is an example of a ping test from my PC to the router IP (5GHz):
ping 192.168.1.1
PING 192.168.1.1 (192.168.1.1): 56 data bytes
Request timeout for icmp_seq 0
64 bytes from 192.168.1.1: icmp_seq=0 ttl=64 time=1906.274 ms
64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=904.388 ms
64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=1.259 ms
64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=5.524 ms
64 bytes from 192.168.1.1: icmp_seq=4 ttl=64 time=56.250 ms
64 bytes from 192.168.1.1: icmp_seq=5 ttl=64 time=96.461 ms
64 bytes from 192.168.1.1: icmp_seq=6 ttl=64 time=2.258 ms
64 bytes from 192.168.1.1: icmp_seq=7 ttl=64 time=35.103 ms
64 bytes from 192.168.1.1: icmp_seq=8 ttl=64 time=45.953 ms
64 bytes from 192.168.1.1: icmp_seq=9 ttl=64 time=58.963 ms
64 bytes from 192.168.1.1: icmp_seq=10 ttl=64 time=9.100 ms
64 bytes from 192.168.1.1: icmp_seq=11 ttl=64 time=1.379 ms
64 bytes from 192.168.1.1: icmp_seq=12 ttl=64 time=8.654 ms
64 bytes from 192.168.1.1: icmp_seq=13 ttl=64 time=8.946 ms
64 bytes from 192.168.1.1: icmp_seq=14 ttl=64 time=1.907 ms
64 bytes from 192.168.1.1: icmp_seq=15 ttl=64 time=1.559 ms
64 bytes from 192.168.1.1: icmp_seq=16 ttl=64 time=1941.317 ms
64 bytes from 192.168.1.1: icmp_seq=17 ttl=64 time=940.940 ms
64 bytes from 192.168.1.1: icmp_seq=18 ttl=64 time=109.900 ms
64 bytes from 192.168.1.1: icmp_seq=19 ttl=64 time=1.505 ms
64 bytes from 192.168.1.1: icmp_seq=20 ttl=64 time=1.970 ms
64 bytes from 192.168.1.1: icmp_seq=21 ttl=64 time=2.832 ms
64 bytes from 192.168.1.1: icmp_seq=22 ttl=64 time=9.493 ms
64 bytes from 192.168.1.1: icmp_seq=23 ttl=64 time=9.438 ms
64 bytes from 192.168.1.1: icmp_seq=24 ttl=64 time=9.685 ms
64 bytes from 192.168.1.1: icmp_seq=25 ttl=64 time=8.857 ms
64 bytes from 192.168.1.1: icmp_seq=26 ttl=64 time=9.169 ms
64 bytes from 192.168.1.1: icmp_seq=27 ttl=64 time=8.818 ms
64 bytes from 192.168.1.1: icmp_seq=28 ttl=64 time=8.928 ms
64 bytes from 192.168.1.1: icmp_seq=29 ttl=64 time=8.732 ms
64 bytes from 192.168.1.1: icmp_seq=30 ttl=64 time=11.618 ms
64 bytes from 192.168.1.1: icmp_seq=31 ttl=64 time=1.356 ms
64 bytes from 192.168.1.1: icmp_seq=32 ttl=64 time=1979.665 ms
64 bytes from 192.168.1.1: icmp_seq=33 ttl=64 time=976.014 ms
64 bytes from 192.168.1.1: icmp_seq=34 ttl=64 time=1.604 ms
64 bytes from 192.168.1.1: icmp_seq=35 ttl=64 time=2.040 ms
^C
--- 192.168.1.1 ping statistics ---
36 packets transmitted, 36 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 1.259/255.218/1979.665/569.237 ms
As you can see there are ping spikes of nearly 2 seconds! I was able to reproduce this issue on all my PCs, mac, windows and linux so I am pretty certain its not a client or OS specific issue but rather with the router possibly?
Here is exactly the same test from my PC to the router IP (2.4GHz):
ping 192.168.1.1
64 bytes from 192.168.1.1: icmp_seq=0 ttl=64 time=9.813 ms
64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=10.325 ms
64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=93.894 ms
64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=133.613 ms
64 bytes from 192.168.1.1: icmp_seq=4 ttl=64 time=4.686 ms
64 bytes from 192.168.1.1: icmp_seq=5 ttl=64 time=58.811 ms
64 bytes from 192.168.1.1: icmp_seq=6 ttl=64 time=2.869 ms
64 bytes from 192.168.1.1: icmp_seq=7 ttl=64 time=44.232 ms
64 bytes from 192.168.1.1: icmp_seq=8 ttl=64 time=62.617 ms
64 bytes from 192.168.1.1: icmp_seq=9 ttl=64 time=75.770 ms
64 bytes from 192.168.1.1: icmp_seq=10 ttl=64 time=2.317 ms
64 bytes from 192.168.1.1: icmp_seq=11 ttl=64 time=1.650 ms
64 bytes from 192.168.1.1: icmp_seq=12 ttl=64 time=11.171 ms
64 bytes from 192.168.1.1: icmp_seq=13 ttl=64 time=8.751 ms
64 bytes from 192.168.1.1: icmp_seq=14 ttl=64 time=1.488 ms
64 bytes from 192.168.1.1: icmp_seq=15 ttl=64 time=8.764 ms
64 bytes from 192.168.1.1: icmp_seq=16 ttl=64 time=1.468 ms
64 bytes from 192.168.1.1: icmp_seq=17 ttl=64 time=1.278 ms
64 bytes from 192.168.1.1: icmp_seq=18 ttl=64 time=9.062 ms
64 bytes from 192.168.1.1: icmp_seq=19 ttl=64 time=8.735 ms
64 bytes from 192.168.1.1: icmp_seq=20 ttl=64 time=1.648 ms
64 bytes from 192.168.1.1: icmp_seq=21 ttl=64 time=1.640 ms
64 bytes from 192.168.1.1: icmp_seq=22 ttl=64 time=8.788 ms
64 bytes from 192.168.1.1: icmp_seq=23 ttl=64 time=3.675 ms
64 bytes from 192.168.1.1: icmp_seq=24 ttl=64 time=1.534 ms
64 bytes from 192.168.1.1: icmp_seq=25 ttl=64 time=8.943 ms
64 bytes from 192.168.1.1: icmp_seq=26 ttl=64 time=3.193 ms
64 bytes from 192.168.1.1: icmp_seq=27 ttl=64 time=121.964 ms
64 bytes from 192.168.1.1: icmp_seq=28 ttl=64 time=1.348 ms
64 bytes from 192.168.1.1: icmp_seq=29 ttl=64 time=48.689 ms
64 bytes from 192.168.1.1: icmp_seq=30 ttl=64 time=5.123 ms
64 bytes from 192.168.1.1: icmp_seq=31 ttl=64 time=8.697 ms
64 bytes from 192.168.1.1: icmp_seq=32 ttl=64 time=1.510 ms
64 bytes from 192.168.1.1: icmp_seq=33 ttl=64 time=8.713 ms
64 bytes from 192.168.1.1: icmp_seq=34 ttl=64 time=10.210 ms
64 bytes from 192.168.1.1: icmp_seq=35 ttl=64 time=1.690 ms
64 bytes from 192.168.1.1: icmp_seq=36 ttl=64 time=1.620 ms
64 bytes from 192.168.1.1: icmp_seq=37 ttl=64 time=8.690 ms
64 bytes from 192.168.1.1: icmp_seq=38 ttl=64 time=1.894 ms
64 bytes from 192.168.1.1: icmp_seq=39 ttl=64 time=1.417 ms
64 bytes from 192.168.1.1: icmp_seq=40 ttl=64 time=35.784 ms
64 bytes from 192.168.1.1: icmp_seq=41 ttl=64 time=122.573 ms
^C
42 packets transmitted, 42 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 1.278/22.873/133.613/36.045 ms
As you can see its a lot more stable despite all my other devices being on 2.4GHz as well.
I am also 3-4 meters away from my router and have line of sight, there are no walls ect. in the way. I have also used NetSpot to check for interfering channels from neighbours, but I am the only one with 5GHz wifi (screenshot 1). In comparison, the 2.4GHz channels are quite congested but I get better stability during ping tests (screenshot 2).
One last thing to note is that I used to be able to play games on 5GHz without any issues at all. This started happening quite suddenly (after a firmware upgrade I am suspecting?) There are also only 8 clients in total connected to the router, 4 of which are wired anyway, so I don't think the router is being strained at all either. I have also reset the router to factory settings and the issue persists.
I also have no USB devices connected to the router at all, only wired LAN cables.
If you are experiencing the same thing or are able to help please let me know. It would be greatly appreciated!
ping 192.168.1.1
^C
ping 192.168.1.1
^C
