Hi Forum,
firstly I want to mention that I am not really into linux, so please be patient. I only know the basics.
I do have a problem starting the rsync daemon on my RT-AC86u Router. I installed asuswrt-merlin (V 382.1_2) and optware using this tutorial:
https://rewster.uk/2016/03/11/running-rsync-on-asus-router/
The outcome should be, that my ASUS router is recognizable from my Synology NAS DS213j as a rsync-compatible server using HyperBackup to execute a remote sync of my important files. My thought was to start the rsync daemon on the router and then configure HyperBackup to do the rsync on a daily basis.
Logging on the router using Putty with root user I can't start the rsync daemon using the command
'rsync --daemon start'
The error message states: 'can't load library libc.so.0'
Searching for the library using WinSCP, the library in fact isn't found anywhere on the router. Nevertheless there are many libraries found in '/tmp/mnt/My-Book/asusware.arm/lib/' like 'libc.so' and 'libc.so.1'
What am I missing?
Thank you in advance for your help!
What am I missing?
