BosseSwede
I have a number of ASUS routers on my different LAN:s and I have successfully upgraded each to the latest ASUS release f/w on all of them except my main router. I have used both the admin GUI (when I had downloaded the f/w file from Asus first) and the ASUS Router App on my phone, which can locate the latest f/w automagically.
I decided to update the main router today from 3004.384_32799 to 3004.386.46092 and used this procedure:
1) Use the web GUI Admin function to save current settings to a file
2) Use the ASUS Router app on my phone to update to 46092
3) After the 3 minutes wait it was supposed to be done, but now BIG PROBLEMS!
At the moment my wifi is visible but it does not hand out any IP address to a connection attempt, so it fails.
On the wired LAN I can ping the router 192.168.119.1 and get a response, I also can do that from a Linux machine connected by wire.
I can still connect by SSH to my other Linux machines on the LAN.
But I cannot log on to the router's GUI, nothing shows up when I browse to the router address.
Same with SSH, there is no connection to that address (refused).
I have tried to power cycle the router to no avail.
What can I do now?
I have googled on this issue but only found answers concerning the AsusWRT Merlin f/w, but I am using stock ASUS f/w.
What can I do now?
