Avinitlarge
I had one of my AC86’s as a node, after a power cut, I noticed the node was not there. I’ve tried resetting it, restoring it to factory and reinstalling the firmware. I’ve tried it as an access point and that works fine. When I try to add it as a node, the master finds the node but fails to connect, the internet light is red on the node.
I’ve tried different cables and ports but it just won’t connect.
I’m a bit confused![Confused face :confused: 😕](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f615.png)
I’m a bit confused
