The 2.4GHz band on my RT-AC87R suddenly stopped working. The thing had been sitting on the same shelf for years; AFAICT, nothing had disturbed it. Is it really possible that the 2.4GHz radio, and only that, just died? It sure appears this way. Let me elaborate:
- Frequent guest complains that they can't connect to the guest network (which was running on the 2.4GHz band).
- Apparently only the 5GHz SSID is being advertised; neither the "real" 2.4 SSID nor the guest network SSID can be seen.
- A visit to the "Guest Network" tab has the first bit of evidence that something is not well: the message "2.4GHz* Turn WiFi on to operate the Guest Network. GO" appears in yellow. OK, maybe somehow it gotten turned off. I follow the GO link, which drops me to the "Professional" tab of the Wireless menu.
- Unsurprisingly, the radio is already on, and nothing looks out of the ordinary.
- Power-cycle, clear to factory defaults, power-cycle again: no go.
- Go to the ASUS site and get the latest available firmware (3.0.0.4.382_52545). Install, reboot, reset to factory defaults, wave a rubber chicken. Still nothing.
- Look at the system log, still from the gui; nothing jumps out in the general log, but the wireless log only shows the 5GHz band:
Not associated. Last associated withMode : AP Only SSID: "FIVE" RSSI: 0 dBm SNR: 16 dB noise: -45 dBm Channel: 153/80 BSSID: 38:2C:4A:xx:xx:xx Supported Rates: [ 6(b) 9 12(b) 18 24(b) 36 48 54 ] Mode : AP Only
- Time to get dirty. ssh into the box.
- `nvram show`, `nvram show | grep wifi` shows expected interface names (wifi0, eth0, eth1, vlan1, vlan2 ...) but nothing jumps out.
- `robocfg show` lists some unexpected (to me) vlans, but I can't tell if they show anything wrong:
