David Ferguson
Hello 1st Post so i'm not used to all the jargon so forgive me if my explanation is not great!!
I have a strange issue with wired connections not getting on to the internet after a reboot (windows pc's) the wired connection is all connected and IP is all assigned alone with all the relevant gateways and dns stuff.
I have a full connection but if I ping the router I get nothing. Sometimes if I wait for say 3-5 minutes sometimes it will eventually connect but sometimes I have to pull the ethernet cable out then back in and this generally solves the issue (not always).
I have tested the connections directly to the router itself and this also exhibits the same symptoms.
The only thing that's changed recently is that I've moved ISP to VirginMediaBusiness, their router is in bridged mode / router mode so the router has no double nat issues. I was previously with BT Infinity.
I have not tried a complete router wipe yet as I have several port forwarding rules and several MAC static ip's setup.
Any suggestions would be greatly appreciated.
Kind regards
Dave
Kind regards
Dave
