RT-AC87U and multiple xbox ones nat problem
kingguile
Hello it would be nice if you can fix multiple xbox one nat problem
i have 3 xbox one in my house and 1 is open nat the other is moderate and the 3rd is strict (no good )
can there be a fix in the near future.
thanks
Only two ways to solve this
1. Enable UPNP - Since you only have 1 external IP and MS provides no way to define alternative ports for Live, it is not something you can fix with simple port forwarding.
2. If you have a native IPv6 connection from your ISP, or can use an IPv6 tunnel such as Hurricane Electric you simply have to allow the proper ports to your IPv6 address
upnp is open and my provider dont give ipv6
thanks
There is no technology I know of that can listen on a single port and selectively forward to 3 devices.
For outgoing connections, everything should work fine.
